guys,
tried searching but couldnt find the exact answer i want..
Do i need to change my clutch pump if i upgrade my clutch to Exedy 4 puck with the semi race cover? Using standard wira pump on Mivec Gearbox..
im having problem engaging the gears...
which part should i change? the bottom pump on the gearbox or main pump?
Pump from which car should i use? evo??
thanks...
thanks...
