4g93T clutch pump?
silverchair
Do 4g93T have clutch pump? I found that my clutch oil is getting lesser, and clutch is getting harder sometime also. So i checked underneath car, i found there is leak at some where rod joint there.
So i went to mechanic and check, they claim that clutch pump failure.. so just want to make sure there is clutch pump for 4g93t? And does anyone know can i just/manage change the "rod joint" to prevent leak? any sifu experienced tis before?
but sometimes repair kit does not work,
if the 'lubang' inside makan already then cannot, have to change the whole pump.
can easily get at kedai potong ma.
