"Check Engine" Light
opie ferio
aloo sifuus....
why the "check engine" light still on?
usually the light goes off after 1 or 2 seconds after I switched on ..... but this morning it won't go off and still on when I starts the engine....
what to check ya?
ask a seasoned honda user to 'jump' the ECU and check see the error code...then u can find wat is wrong with ur car....
if dunno how to jump the wire get to a workshop with dianogtic box and it will tell you :) hopefully nothing big :)
opieferio ..
I believ yur car is an EG .. find the service connector .. normally for eg is on under yur glove box .. it normally green in color .. find a paper clip .. short circuit it .. the check engine will start blinking .. kira berapa .. tengok manual
yup ... mine's is EG8.....
checked oredi...
1) O2 sensor kong ....
2) Air Temp sensor socket also kong....
thanks guys for the info.... ;)
Funny... my air temp also had a prob earlier.. u know what ? the sensor was bent! wonder what went in the intake that could bend it.. cannot be the force of the air is too strong..
