Check engine light on
GO TO WIRING SPECIALIST.... u need computer to red the ecu.... then we know what problem.... my car happen once.... only temp sensor longgar... he charge me rm20 for troubleshooting.... go see panjang.... ulu kelang
Bump: GO TO WIRING SPECIALIST.... u need computer to red the ecu.... then we know what problem.... my car happen once.... only temp sensor longgar... he charge me rm20 for troubleshooting.... go see panjang.... ulu kelang
Ape nama woksop tu?
i use 3s-gte in my ST150. just happen the same scenario for half year. i just consider wiring problem. last time i go to workshop for wiring my fuel pump and mechanic found that alternator gone wrong. replace the alternator and the result all the warning light on my meter gone. so my advice go to check the alternator.
yerterday i removed the thermostat then the engine always cool check engine light also not lighted but when i running high speed the check engine light come back lighting. i think maybe due to speedo meter faulty. any comment...
use a jumper wire between the diagnosis socket's E1 & TE1 then 'on' ur ignition key and observe the check light's blinking rate then it will tell u wat to trace...
sory all bro's actually my problem already settled when i fix my speedo meter last month. actually speedo meter also affected to check engine light. after i fix my meter the light not lighting anymore. sory i forgot to close this thread.
Bump: sory all bro's actually my problem already settled when i fix my speedo meter last month. actually speedo meter also affected to check engine light. after i fix my meter the light not lighting anymore. sory i forgot to close this thread.
