Car Vibration????
khairunizan
Dear fellows,
I've some problem with my car...;
what is really suck is my car having to vibrate when speed at 130km/h and above..
Below that speed, very comfortable... i already doing balancing... oso On-Wheeled Balancing. But my car still vibrate..
i dun know wat to do anymore??
any idea frens?? :D
If the car vibrate during a certain speed, the most likely cause is unbalanced tyre. Try to redo your tyre balancing at another shop.
The easiest way to isolate an out of balance wheel is to rotate the suspect wheel and see if the location of the vibration changes. If you feel it in the steering wheel, move the front wheels to the back, and see if it is now felt in in the seat or under your feet.
Of course if you just got a new set of tires and neglected to balance the wheels, you may get a vibration from all four wheels. If the vibration appears out of the blue, check the wheels to make sure a balancing weight did not fall of.
