brake problem dc2 SiR with ABS
  • Thread starter Thread starter achor
  • Start date Start date
A
achor
Guest
i've been experiencing quite a strong vibration when braking with speeds more than 100km/h. i've skimmed my disc n replaced my brake pads. but my car still vibrates with speed more than 100 km/h. anybody knows what is causing my problem? :confused_smile: does it lies with my master pump? or the ABS system itself? or my brake lines has worn out? but when braking, i've got no problem. it stops. but with tremendous shaking! if balancing is the problem, the car must vibrate even when i'm not pressing the brakes rite? but this vibration only happens when braking with speeds more than 100km/h. if lower, no vibration felt. why ar?
Cld b your discs are warped. Sometimes skimming may not help. Only thing is to change the discs. Best thing is to ask your friendly mechanic. He knows best.
warped? even skimming can't help? hmm... does that mean i have to change the brake pads again too?
since it only happens at high speed braking, why dun u try bleeding the entire brake fluid system and see what happens. do not re-use the dot3 fluid. get a brand new bottle.
ps. since u have ABS, drain all the fluid from there too.
bleeding the whole system? hmm... there's something that i haven't tried. thanks for the advice. i'm running on dot 4 rite now.
dun forget your brake pads. see if there are not grooved by whatever that makes the vibration. other than that the last resort will be your shocks or rarely your engine mounts. at high speed things are not the way it seems when its at slow speed.
just my 20 cents.
mina~ , everyone, i went to my mechanic yesterday. he said i should try to do wheel balacing 1st. because he said, "i don't think the disc is making the vibration." so he suggested that i should try do wheel balancing 1st. hmm... it's been a while that i haven't done that.
