can diy short shifter?
Originally posted by general+Oct 25 2004, 21:42 -->
QUOTE (general @ Oct 25 2004, 21:42 )
--QuoteBegin-khguan
@Oct 25 2004, 13:35
got one question,
if i change to short shifter.. will i need more force to shift gear?
for 1st gear.. maybe..but not for 2,3,4,5 or R [/b][/quote]
why not on 2,3,4,5 and R??? mind to explain??
sorry cant xplain further, juz thru my experince cos i'm using quick shift..
Do u have a photo of it? Why u selling it off?
update with pix. this is not mine but same exactly like this.. selling of coz upgrade to adjustable quick shift... :D
http://images.cardomain.com/member_images/3/web/447000-447999/447461_84_full.jpg
this is gear shirter right?? look this can be adjustable one, right?? how to shorter if it cannot be adjusted? just cut it short loo....:D
u cut de stick no use wan ah... de shifting distance only reduced a little... and make it more heavy to shift gears...
short shift means de shifting distance is reduced..u dun have to push ur gearstick so far to change gear...
u can watch 2 fast 2 furious.. look at de guy shifting gear in his rx-7 if not mistaken.. he just push de gear stick a bit can change gear liao... B)
this one not adjustable laa...
got it....if can shift gear so short, then have to have adjust the gear position, not shorter the gear stick.....right??
What's the difference between a quickshift and a shortshifter?
When u say adjustable.. do u mean the length of the gear stick?
