A ayip87 Junior Member Senior Member Aug 22, 2010 #1 I want to ask all sifu here about short shifter. I've changed gear short shifter brand Jasma today but after changed, it become hard to change gear..Is it normal gear changing become hard after using short shift? Thanks in advance..
A ap3xi Known Member Senior Member Aug 24, 2010 #2 sure need more power to shift gear but i dunno your case how hard la
^pomen_GTR^ 7,000 RPM Senior Member Aug 24, 2010 #3 playing with short-shifter=playing with physic...(fulcrum point) shorter lever=less travel=higher force needed to move the load...(gear change) hard/heavy depends on ppl...since some ppl can tolerate...some can't....
loose_end 3,000 RPM Senior Member Aug 25, 2010 #4 Your physics really make sense , now I understand why some people that are using short shifter says that it is much harder to shift compared to stock
S SataniC Old Is Gold Senior Member Aug 25, 2010 #5 yup...same goes to steering wheel, the smaller the size the lesser u need to turn...and the harder during parking...without power steering of cos :P
