C56 = lsd ???
ipul_AE111
hello sifu2 n otai2 Toy here,
i'm confuse about this C56 gbx.
mine 1 is 5speed de..
want to identify is it LSD or not.
some my buddys say its not LSD
maybe true bcos when car 'tergantung'
then rotate each wheel to 1 direction, the opposite 1 will rotate in same direction is got LSD right?
but mine not like that. when rotate each wheel, the other 1 will rotate in 'arah bertentangan'.
im worring about the gbx oil, want to change already bcoz the drvshft oil seal pecah already one side,
i think the oil oso in few amount only.
last time 1st fill after tranplant BT engine, im using toyota brand LSD gbx oil RM68.
the autopart taukeh rekemen me, say if LSD gbx fill with non type oil, the gbx will 'cepat' condamn
if non LSD leh, put any type of gbx oil will no problem.
in your case...certain C56 GB came equipped with LSD...some not...well not some...most is not equipped with LSD...if i'm correct typically LSD equipped GB (1 way, 1.5 way, 2 way) will spin both of the tire in same direction if you spin it (that the general guide line...if really want to make sure...have to open up the GB)...if both spin the same way...congrats...you got LSD... and there is wide choice of LSD lubricant to choose from...like you said ori toyota also got LSD oil...
if normal GB also there is wide range of lub to choose from...just make sure the correct and suitable viscosity rating for you application...
Not really too... I also got LSD but when use hand to spin it, 1 side only spin, 1 side stand still. But once enter gear and throttle it, both wheel spin equally. :hmmmm:
that why i said..."general" rule...not "confirm already" rule...another method worth mentioning is looking at the engine number plat at your halfcut...there also should have the GB code stamp onto it...if LSD is factory fitted...it should be mark with "c" like C56-C or something like that...
albeit all that fuss...it seems that yours is normal GB...if i'm not mistaken....LSD lub not suitable for your GB
If torsen LSD (which most FWD toyota is equipped),both wheel will still turn opposite of each other just like normal open differential,only when you apply power the LSD will take effect.If clutch type LSd,then both wheel will turn same direction
Another way to test if got LSD or not is to jack up one wheel only and try to spin it with neutral gear. If LSD, it will be hard to spin (requires force) or you cant spin the wheel at all. This will 99% confirm if your GB has LSD.
Using LSD oil on non-LSD box will not be an issue (just more costly) but using non-LSD oil on LSD box will damage your LSD.
thanks for all advise n replys.
i'm still doing researh. i think should go to BT speacialist to kenal pasti the status of my my GB.
the summary is not all C56 got LSD lor..
haa..sumore 1 thing,
i feel lil bit hard to shift gear from 1st to 2nd, then to the 3rd in low RPM (below 3500RPM)
hv to play-play with fuel pedal then can shift smooth.
is it im using wrong type of oil for my GB?
check already at the identity plate of the h/c,
writed as below..
MODEL : E-AE111G-CWMVF
ENGINE : 4A-GE 1587 cc
FRAME No. AE111-7004812
COLOR TRIM GVM(KG)
205 YR16
TRANS./AXLE : C56 -04A
PLANT/BUILT : B11
just like that only... can identify it has LSD or not meh this way:confused:
To be more accurate .. Better u snap a picture of the drive shaft hole of ur gb... Sure many sifu here can help u identify....
For oem or trd LSD - either 1 side will do.
If rare item need to have 2 side to judge ...
Better take 2 side lo.... Haaha.. Good luck to u
