Boost Control Solenoid
silver_knight
MD Racing
This MAC valve has the new heavier duty wires.The older style valve had brown thin wires,the new wires are black, thicker and much more flexible and withstand heat better. This is the same 3 port boost control used by many boost control manufacturers ,we buy in high volume from the same valve manufacturer as they do and it is the exact same valve ... minus the sticker and the inflated price!!!. Can be used as a 3 port or 2 port solenoid. Includes (2) 3/16" brass hose barb fittings. All the Ports are 1/8 NPT so you can use any common fitting that you want including AN-adapters. Also includes one sintered high flow air muffler/vent filter. The sintered filter makes the installation easier & cleaner because you don't have to run another hose to your air cleaner. The fittings are injcluded (brass). This boost control solenoid will not degrade from rich fuel mixtures or oil . Very high life and very resistant to sticking from contamination. - Leads are 18" long. - 12 volt DC , polarity not sensitive. - 5.4 watts - 10-90% duty cycle - 1/8" npt ports
Compatible with many & most boost controllers and ECU's : AEM,Autronic,E-boost etc,Neptune, Hondata,ECtune,Megasquirt,VEMS,Haltech. - operating range vacume to 120 psi. - (2 ) 3/16" bhose barbs nipples - (1) sintered vent/muffler - This is an industrial quality valve, Autronic,e-boost and AEM have been using them for years on everything from rally cars to drag cars, there is a reason they use this valve, it is very durable and responsive. - Installation tips will be emailed to the purchaser as soon as the order is placed. - This valve can be driven by many stock ecu's as well as many aftermarket stand-alones and regular stand alone boost controllers.
https://www.facebook.com/HDTmotorsport
Price rm320
Loc Sek 27 Shah Alam
call/sms/whatsapp
0182131320 -matt-
