GReddy Profec Boost Controller
powerautohauz
((( God Level 30,000 RPM )))
GReddy PRofec Electronic Boost Controller
The new PRofec is compact, powerful and easy to use. The large OLED Display, with the simple two-button / rotary-dial control, make for intuitive operation. An ultra slim controller can display in digital, bar-graph, or graphical modes and can be rotated 180 degree for installation with the included adjustable mount or flush mounted. By separating the display and control unit in the driver’s compartment, from the engine compartment-mounted, waterproof, sensor unit, it makes installation straightforward. The combination of the new 300kPa (43.5psi) integrated pressure sensor, the more compact solenoid valve and faster ECU processer, provide quicker response and the most stable boost curves yet. The next evolution of the GReddy PRofec line of electronic boost controllers is here!
- 89 x 36.5 x 22.8mm
- Color OLED Display
- built in Boost gauge (kPa or PSI)
- 3 display types - Numeric, Bar Graph, & Map Graph
- Intuitive Control Screen and Dial control
- 2 preset setting, LO & HI, with 3rd timed Scramble boost setting
- (Lo. & Hi.) Set % - to increase boost
(higer number, higher the boost over base boost level)
- Warning point, warning limiter, peak-hold/Last boost compatiable with both actuator style and external wastegate style turbo systems revised compact boost solenoid
- Separated Display/Control Unit and Sensor
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Land Mark:
Desmond 017-396 8567
Email us : [email protected]
