Bolt on turbo kit
How much and where did youget it done? From pic workmanships looks good. Hows the power improvements and fuel consumption?
razaksa :
when i never boost my car , fuel consumption running original cause i never change my main injector , only fuel consumption higher when i boost , extra injector help to supply extra fuel to my engine . now running 0.8 bar. i did it at Drager Racing .
L9Turbo :
you may be right , there is a lot of turbo honda out there , but did you come across any honda turbo boosting 0.8 bar without changing piston = i mean using back high compression piston , without adding thicker metal head gasket = i am using stock standard gasket , consider high boost = 0.8 bar on every gear and been using this car for a year plus without giving any overheat , engine blur , pinking problem.
Bro naszal :
at this timing i am using TD-05H with e-manage ecu to tune my car.
Bro razaksa :
yup bro , i did it at turbo sang place , but now he is no more at PJ , he move to Kepong already , turbo kit + e-manage is about 6k plus installation. worth to pay for it.
http://www.vazmaz.com/gal-alfavtec.htm
ALFA 155 POWERED BY HONDA VTEC H22A TURBO ENGINE
USING MICROTECH LT8 ENGINE MANAGEMENT SYSTEM
JZ SHARING.. :)
quottro :
Bro , Turbo Sang shop call Drager Racing , located at Kepong , Tmn Perindustrian Ehsan Jaya , close to Sri Damansara.
Phone : 03-62754508
eovaz :
Bro , really can't imagine alfa can go in v-tec turbo , is that you car ? is it from malaysia ? how much you spend on your turbo kit ? i spend about 6k to completed my kit....
civic sohc internals is quite strong suprisingly.
boosted my sohc at 1bar. no changing of pistons. stock internals. no prob after running 1 year. power output is suprisingly high as well ;)
nice kit u have there dude :)
wah boosting at 1bar????
one year aledi???
wahh i oso wanna to but ek 4 pintu ler lit dat....heheheh...put 6k aledi get turbo....heheheh no need change to vtec's.....which 1.6 no need change pistons???
soch or soch vtec???? <_<
one year aledi???
soch or soch vtec???? b]
im not sure normal sohc need or not....
but mine is 1.6sohc vtec. d16y8. pistons are kinda stronger than i expected ;) mine is ej7 - 4pintu also ma. but sold off this car 1/2 years back :)
