B-series cam specs
evoX2
found something to share:
Why CTR cam is different from ITR 2000/01??
source: honda-acura.net
Stock - Following Measured @ .050"
- B16A2 (Civic SI)
Int - 224
Exh - 220
- B18C (Integra GSR)
Int - 236
Exh - 224
- B16B (JDM Civic Type R)
Int - 240
Exh - 232
- Following Measured @ 1mm lift
- B18C (Integra Type R through 1999 spec)
Int - 240
Exh - 235
(Integra Type R 2000/2001 spec)
Int - 243
Exh - 235
Aftermarket - Following Measured @ .050"
- Crower Stage I
Int - 242
Exh - 234
- Crower Stage II turbo design
Int - 233
Exh - 235
- Crower Stage II
Int - 255
Exh - 248
- Crower Stage III
Int - 263
Exh - 255
- All Crower primary and secondary lobes are as follows...
Secondary - 206
Primary - 206
- Skunk2 Stage I
Int - [email protected] lift
Exh - [email protected] lift
- Skunk2 Stage II
- Skunk2 Stage III
- JUN Type I
- JUN Type II
- JUN Type III
- Spoon Sports
- Following Measured @ 0mm lift
- Toda Spec A
- Toda Spec B
- Toda Spec C
- Toda Spec D
- Buddy Club N1 Spec III
- Buddy Club N1 Spec IV
i think this source is inaccurate or typo.
Integra Type-R Pre '99 Spec
Int-240 dur. / 11.5mm lift
Exh-235 dur. / 10.5mm lift
Civic Type-R And Integra Type-R
Int-243 dur. / 11.5mm lift
Civic Type-R '97-'00 And Integra Type-R '00
this is correct!
btw, want to ask if normal b-series change to tep R cam & spring,is it neccessary to tune the engine by vafc or e-manage?
yup VAFC still the simplest and fastest way to tune. for NA...
My style.. run around a few times.. look at plug..if too lean.. add fuel with regulator, if not.. then leave it as it is.
lower end sucks after adding fuel? remove with VAFC.
