G1Racing E-Store Garage Sales
G1Racing
Services
G1Racing Showroom And Services Centre Prai Penang
http://www.zerotohundred.com/newforums/car-shops-and-services/431006-g1-racing-showroom-and-service-center-sunway-selangor.html
Liqui Moly Jetclean Tronic Carbon Cleaner for Petrol and Diesel Engine OFFER!!
Special Deal
Turbo S Extractor 421 Satria Neo CPS
Engine And Performance
Power Enterprise Super Kevlar II Performance Timing Belt
Apexi N1 Universal Muffler For NA / Turbo
Toda Sport Heavy Duty Oil Pump Gear 84mm
RaceTech Solid Shifter WorX Shifter Base Bushing for Proton
Works Engineering Stage I Fuel Regulator
S90 Racing Throttle Body
Works Engineering Power Plus Throttle Body
S90 Racing Throttle Body Honda Integra DC5 70MM OFFER !!!
S90 Racing Throttle Body Proton 12V 62MMOFFER !!!
AEM Adjustable Fuel Pressure Regulator
Turbo S Stainless Steel Extractor 4-2-1
Denso Iridium Tough Spark Plug
AEM High Volume Fuel Rail
Turbo Smart special limited-edition UltraGate 38mm Wastegate
Arospeed Engine Damper Kit
Cometic Metal Gasket for Various Engine model Offer!!
Diesel Blow Off Valve System For 4X4 Or Diesel Turbo
CKW BlowOff Valve Sheepdog type
Turbo Smart BOV Dual Port Universal
Turbo Smart BOV Vee Port Universal
Turbo Smart BOV Super Sonic UniversalNGK Iridium IX Spark Plug
Denso Iridium Power Spark Plug
Works Engineering Adjustable Cam Gear
ACL Engine Bearing
Mythelogy Performance Lighten Crank Pulley Proton Gen2
Mythelogy Performance Lighten Crank Pulley K3VE Myvi Toyota Rush Terios
Redline Lighten Performance Crank Pulley
OS Giken Super Single Racing Clutch
Ogura ORC Subaru GDB Ver9 6 Speed Twins Plate
RBP Super Single Racing Clutch
RBP Super Single Racing Clutch EVO123 Offer !!!
Greddy Type S Rz Blow Off Valve
NGK Racing Power Plug Cable
High Performance Boost Controller CHEAP CHEAP CHEAP !!!
Nology Silver Spark Plug
Nology PowerCore Ignition Coil Amplifier
Nology Hotwires Spark Plug Wires
Carspeed High Voltage Ignition Coil
HKS SQV2 Blow Off Valve
Arospeed Aluminium Harden Cam Gear
Performance Stiff Ring
Wiesco Forged Pistons for EVO123 / GSR
ARP Engine Head Stud
Arospeed Aluminium Harden Lightweight Crank Pulley
HKS Genuine Camshaft[/URL]
Walbro Intank 255LPH Performance Fuel Pump[/URL]
Supertech Black Nitrided Dish Race Valves Honda B Series
Supertech Block Guard Honda B Series
Jun Genuine Camshaft for 4G63 EVO1-3
Works Engineering Boost Controller
Works Engineering Pro 400 Clutch
Exedy Racing Clutch
D&D Twins Plate Racing Clutch Kit
NGK Laser Platinum Iridium RX7 RX8
Arospeed Tri-Core Plug Cable
Ogura Super Single Racing Clutch
Supertech 5.5mm Valve Stem Seal Vilton Honda B Series
Duratec Camshaft with Valve Spring 272 Degree 4G93 GSR
Duratec Camshaft with Valve Spring 288 Degree 4G93 GSR
Piper Hi-Cam 4G15 288°
Tomei Fuel Rail for L2
Sard Fuel Rail EVO123 4G93 GSR
Intake & Filter
K&N high performance air filter
Redline high performance dropin air filter EG
Redline dropin filter for 12v carburetor
Blitz Metalic Drop In Filter
K&N Open Pod Air Filter
Works Engineering Aeroform Air Intake System
K&N Typhoon Cold Air Intake Systems
Simota Twister Big inlet Intake With Simota 4.5 inch Filter Kit EK EG
Skunk2 Intake Manifold
Works Engineering Performance drop-in filter
Works Engineering Performance drop-in filter Toyota Wish/Camry/Altis/Caldina ZTOFFER!!
Works Engineering Performance drop-in filter Toyota Estima/Alphard/CaldinaGT4/HarrierOFFER!!
Works Engineering Performance drop-in filter Honda Accord/Jazz/City/Odyssey/CRV OFFER!!
Works Engineering Performance drop-in filter Honda Civic ES/EK/EG/EJ/FD1/FD2OFFER!!
Works Engineering Performance drop-in filter Perodua Myvi/Viva/Alza/Kelisa/KenariOFFER!!
Works Engineering Performance drop-in filter Proton Perdana V6/Savvy/Saga BLM/Preve OFFER!!
Works Engineering Performance drop-in filter Proton Inspira/Waja/Wira/Satria/Neo OFFER!!
Works Engineering Performance drop-in filter Proton Persona / Gen2 / Satria Neo CPS OFFER!!
Works Engineering Performance drop-in filter VW Golf MK5/MK6 GTI/Passat/Jetta OFFER!!
Works Engineering Performance drop-in filter Lexus GS350/430 OFFER!!
Works Engineering Performance drop-in filter Lexus IS220/IS250/IS350 OFFER!!
Arospeed Ceramic Coating Ram Pipe
K&N recharger cleaning kit
Simota Innovate Aero Form Air Intake System
Velocity Custom Made Performance Intake Manifold Myvi
Velocity Custom Made Performance Intake Manifold Kelisa
Velocity Custom Made Performance Intake Manifold Waja 4G18
Velocity Custom Made Performance Intake Manifold GSR Turbo
Velocity Custom Made Performance Intake Manifold GSR NA
Velocity Custom Made Performance Intake Manifold EVO4-8
Velocity Custom Made Performance Intake Manifold EVO1-3
Electronic & Gauge/Meters
HKS VAC Speed Cut Defender For RX8
Works Pro Adjustable Energizer (Voltage Stabilizer)
Redline E-Throttle Controller
Haltech IQ3 Logger Dash
Greddy E-Manage Ultimate ECU Management System
Haltech Platinum Sport 1000 Standalone ECU
Microtech LT10S Standalone ECU
Pivot Raizin Voltage Stabilizer
Works E-Drive Electronic Throttle Controller
New Works E-Drive Electronic Throttle Controller for BMW 5 Series NEW!!!
Pivot Spark Earth High Ignition Earth System
Apexi Rev Speed Meter (RSM)
Pivot Mega Raizin
Pivot Speed Meter-V
VI Performance Monitor ODBII compliant
Buddy Club Vtec Controller
Apexi Auto Timer for NA / Turbo
NRG Boost Oil Water Voltage Fuel Oil Exhaust Meter
Greddy E-Manage Support Tool
Apexi AFC Neo Fuel Management System
Works EnginManagement-EMS1 Piggy Back
HKS Nano Tech Grounding & Alternator Power Cable
Works Engineering 24K Gold Plated Super Grounding Cable
Tein EDFC Electronic Damping Force Controller Kit
Sprint Booster for Toyota Vios Honda Mitsubishi
Sprint Booster For VW BMW Benz Civic Lancer Camry
Sprint Booster for 4WD or 4X4
RaceChip Pro2 Chiptuning
Brake & Suspensions
Energy Suspension Hyper Flex Poly Bush Kit For Honda Civic EK EG OFFER!!!
OHLINS DFV Shocks Suspension Kit
FGK Motorsport HiloAdjustable Kit for Proton Wira/Waja/Gen2/Persona/Satria OFFER!!!
FGK Motorsport Hilo Adjustable Kit for Proton Perdana Body Shift OFFER!!!
FGK Motorsport Hilo Adjustable Kit for Proton Preve OFFER!!!
FGK Motorsport Hilo Adjustable Kit for Perodua Kancil OFFER!!!
FGK Motorsport Hilo Adjustable Kit for Perodua Myvi / Viva / Kelisa / KenariOFFER!!!
Textar Brake Pads for European Cars Audi VW Mini
Bendix General CT Performance Brake Pad for Toyota Vios 07 (F) OFFER !!!
Bendix General CT Performance Brake Pad for Perodua Myvi 1.3 (F) OFFER !!!
http://www.zerotohundred.com/newforums/chassis-and-wheels/430436-bendix-general-ct-performance-brake-pad-for-perodua-myvi-1-3-1-5-lagi-best-f.html#post1064286168 OFFER !!!
Kings Performance Replacement Coil Springs for Pickup
Mintex Racing Performance Brake Pad for Porsche 911 / 964 Turbo YR95
DD 6pots Performance Caliper kit for BMW Z4
DD Hilo-Softhard Adjustable Kit for Chevrolet Cruze
DD Hilo-Softhard Adjustable Kit for Toyota Wish
DD Hilo-Softhard Adjustable Kit for Suzuki Swift
DD Hilo-Softhard Adjustable Kit for Audi TT Coupe
HWL Hilo softhard adjustable kit EK
Tein S-Tech Lowered Sport Spring
Tein S-Tech Lowered Sport Spring Alphard Vellfire
Tein S-Tech Lowered Sport Spring Nissan Grand Livina
Tein S-Tech Lowered Sport Spring Satria GTI / Neo
Tein S-Tech Lowered Sport Spring Vios
Tein S-Tech Lowered Sport Spring Toyota Vios 07 Onward
Tein S-Tech Lowered Sport Spring Toyota Vellfire
Tein S-Tech Lowered Sport Spring Honda City
Tein S-Tech Lowered Sport Spring Civic FD/FD2 HOT HOT OFFER!!!
Tein S-Tech Lowered Sport Spring Myvi HOT HOT OFFER !!!
Tein S-Tech Lowered Sport Spring Suzuki Swift
Tein S-Tech Lowered Sport Spring Inspira / Lancer GT HOT HOT OFFER!!!
Tein S-Tech Lowered Sport Spring Civic ES
Tein H-Tech Lowered Sport Spring Toyota Caldina GT4
Tein H-Tech Lowered Sport Spring for Honda CRZOFFER!!!
Tein H-Tech Lowered Sport Spring for Honda InsightOFFER!!!
Tein H-Tech Lowered Sport Spring for Mazda3 08OFFER!!!
Tein H-Tech Lowered Sport Spring for Mazda6 08OFFER!!!
Zerone Sport Lowered Spring
ZERONE SSR 700 Coilover Kit
ZERONE SSR 500 Coilover Kit
ZERONE SSR 300 Coilover Kit
HWL Hilo adjustable kit
Kayaba Pro RS adjustable kit Kelisa/Kenari
Pro RS Brake Hose
Arospeed Steel Braided Brake Hoses
ASR+Beaks Bar for Wira/Satria GTI Neo/Waja/Persona HOT OFFER!!!
ASR+Beaks Bar Honda Civic EK / EG HOT HOT OFFER !!!
D&D Aluminium Rear Lower Arm
Zerone Lighten Lower Arm For Wira
Vogtland Sport Lowered Spring
ULTRA RACING Stabilizing Strut Bar
Project MU Bestop Performance Brake Pad
Tein Street Advance Adjustable Absorber Damper Kit Honda CRZ
Tein Street Advance Adjustable Absorber Damper Kit Toyota Alphard
Tein Street Advance Adjustable Absorber Damper Kit Toyota Vellfire
Tein Street Advance Adjustable Absorber Damper Kit Honda Odyssey
Tein Street Advance Adjustable Absorber Damper Kit Toyota FT86
Tein Type Flex Adjustable Absorber Damper Kit Honda Civic FN2
Tein Type Flex Adjustable Absorber Damper Kit Honda S2000
Tein Type Flex Adjustable Absorber Damper Kit Toyota FT86
Tein Type Flex Adjustable Absorber Damper Kit Mitsubishi Lancer Evo X
Tein Mono Flex Adjustable Absorber Damper Kit Toyota FT86
Tein Mono Flex Adjustable Absorber Damper Kit Subaru Impreza Ver.X
Tein Mono Flex Adjustable Absorber Damper Kit Honda Integra DC5
Tein Mono Flex Adjustable Absorber Damper Kit Mitsubishi Lancer Evo X
Tein Super Racing Adjustable Absorber Damper Kit Nissan GTR35
BC Racing adjustable coilover kit Proton Saga BLM HOT HOT OFFER!!!
BC Racing adjustable coilover kit Myvi 1.3 / 1.5 Lagi Best HOT HOT OFFER!!!
BC Racing adjustable coilover kit Proton Perdana
BC Racing adjustable coilover kit Honda Accord 90-97
BC Racing adjustable coilover kit Honda CRZ
BC Racing adjustable coilover kit Honda S2000
BC Racing adjustable coilover kit Honda Accord 2.4 YR08
BC Racing adjustable coilover kit Hyundai Sonata 2.0 YR2010 Onward
BC Racing adjustable coilover kit Proton Satria Neo
BC Racing adjustable coilover kit Nissan Grand Livina
BC Racing adjustable coilover kit Toyota Wish 2.0
BC Racing adjustable suspension kit V1 Series
BC Racing adjustable coilover kit Ford Focus 04
Hardrace Rear Lower Arm Honda Civic EG
Hardrace Rear Lower Arm Honda Civic EK
Hardrace Rear Lower Arm Honda Civic ES / EP
Interior/Exterior & Body
HKS Kansai Aluminium Bumper Diffuser
Sparco Bumper Clip OFFER!!!
PIAA SS-R Radiator Valve Cap 54S/56S
Aerospeed Engine Oil Cap
Arospeed Aluminium Wires Clip
Sparco Bonnet Clip
Carbon Fiber Bonnet Hood
HKS Carbon Fiber Hood Adjustable Bracket
PIAA Night Tech Hyper Plus Plasma Yellow Ion Bulbs
Stainless Steel Narrow Bolt for NA Turbo
Fuel Regulator Adaptors
PIAA Radix Silicone Wiper
PIAA Silencio X TRM Wiper for Benz BMW Audi VW
Works Engineering Engine Oil Cap
PIAA Sporza Silicone Wiper
Komo Bonnet Absorber
Gear Short Shifter
Engine Plug Cover (Various Model)
Oils & Fluids
Kaaz LSD Gear Oil
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/424396-lucas-deep-clean-fuel-system-cleaner.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/422626-sumo-spec-r-fully-synthetic-engine-oil.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/423608-total-quartz-9000-5w40-fully-synthetic-engine-lubricant.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/423067-lucas-octane-booster.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/424342-motul-trd-sport-engine-oil-5w40.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/424293-redline-waterwetter-coolant-additives.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/422628-sumo-spec-r-semi-synthetic-engine-oil.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/423265-lucas-pure-synthetic-oil-stabilizer.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/424316-lucas-semi-synthetic-10w-40-engine-oil.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/422738-lucas-transmission-fix-oil.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/422651-motul-high-performance-lubricants.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/422746-lucas-engine-oil-stop-leak.html
http://www.zerotohundred.com/newforums/automotive-wear-and-ware/423776-total-quartz-7000-10w40-semi-synthetic-engine-lubricant.html
Torco TR-1R Racing Engine OilHOT ON SALE!!!
Liqui Moly MoS2 Leichtlauf Engine Oil (4L)NEW ARRIVE!!
Silicone Hoses
Silicone Radiator Hose Kit EK/EG/B Series
Silicone Radiator Hose Kit Evo X
Silicone Radiator Hose Kit Evo123 4G63
Silicone Radiator Hose Kit Impreza STI WRX GC8 EJ20 2.0 VER3-6 YR96-2000
High Quality Silicone Hose
Silicone Radiator Hose Kit GSR 4G93
Top Grade Silicone Radiator Hose Kit
Silicone T Joint Hoses
Silicone By Pass Hose for Proton Wira 1.6
Wheel & Nuts
Rays Racing Long Nut
P.MU Floating Racing Nut [Replica]
Blox Racing Nut
Cooling Systems
Arospeed Oil Cooler Kit
Works Engineering ATF Cooler Kit
D&D Performance Radiator Toyota Nissan Honda Subaru Mazda Proton Perodua OFFER !!
Others
GoPro HD Hero2 Camera for Motorsport
PIAA Airy C Aircond Filter (With Vitamin C ) OFFER!!
http://www.zerotohundred.com/newforums/interior-and-cockpit/432303-piaa-airy-c-aircon-filter-for-toyota-alphard-estima-vios-camry-caldina-prius-wish.html#post1064304715 OFFER!!
PIAA Airy C Aircon Filter for Lexus IS250,350 GS350 430 450 460 OFFER!!
http://www.zerotohundred.com/newforums/interior-and-cockpit/432301-piaa-airy-c-aircon-filter-for-nissan-ad-x-trial-skyline-gtr-teana-slyphy-latio-almera.html OFFER!!
http://www.zerotohundred.com/newforums/interior-and-cockpit/432304-piaa-airy-c-aircon-filter-for-honda-civic-accord-city-jazz-stream-odyssey-crz-crv.html#post1064304717 OFFER!!
http://www.zerotohundred.com/newforums/interior-and-cockpit/432308-piaa-airy-c-aircon-filter-for-mitsibushi-evo-airtrek-pajero-mirage-asx.html#post1064304732 OFFER!!
http://www.zerotohundred.com/newforums/interior-and-cockpit/432324-piaa-airy-c-aircon-filter-for-mazda-2-3-6-rx8-cx5-cx7.html#post1064304786 OFFER!!
http://www.zerotohundred.com/newforums/interior-and-cockpit/432337-piaa-airy-c-aircon-filter-for-suzuki-alto-swift-sport.html#post1064304885 OFFER!!
http://www.zerotohundred.com/newforums/interior-and-cockpit/432328-piaa-airy-c-aircon-filter-for-subaru-impreza-gd8-gd9-gc-legacy-xv.html OFFER!!
    [email protected]
G1Racing
Loon 016-2010608
---------- Post added at 06:41 PM ---------- 6 hour anti-bump limit - Previous post was at 05:17 PM ----------
G1Racing
Loon 016-2010608
---------- Post added at 06:41 PM ---------- 6 hour anti-bump limit - Previous post was at 06:41 PM ----------
G1Racing
Loon 016-2010608
G1Racing
Loon 016-2010608
---------- Post added at 02:36 PM ---------- 6 hour anti-bump limit - Previous post was at 02:27 PM ----------
G1Racing
Loon 016-2010608
