automatic transmission indicator problem
2731
Hi, my Toyota Camry 96 automatic transmission indicator doesn't work. I did check behind the meter, there is no bulbs to change.how can i solve this problem? need to replace whole meter?thanks.
Yes, all P,R,N,D,2,L doesn't work. I did shift from P to L, but it doesn't work, mean no light on that indicator. But others indicator in meter is working well, just that 1doesn't work. At first, i thought is the bulb problem, but there is no bulb to replace. I din check then current yet, bcos i dun hv device to check it.
Thanks
