Auto gearbox
skyline2778
I'm askin on behalf of a friend who's drivin wira auto...when the engine is cold(ie after start engine),the gear doesnt shift until when the revving is till 5k.The car seems to be draggin plus feels like no power. But after the engine has warmed up, it's back to normal. It only seems to happen when after just starting up the car. According to one mech, he said gearbox problem.So to make sure askin all ZTH cifus first.TQ.
Actually the gearbox oil just recently changed,abt last week or so. Actually the car was recently involved in an accident but not so serious one la....
i think wira's auto transmission is like tat one.. regarding it has only 3 speed so when de engine is cold needs more power to shift to next gear..
it could be the auto gear clutch....yes; auto also got clutch.
My car although not wira also got the same problem; but it's more than 10 years d. I got to step on it; then depressed a liitle bit to get the gear to shift. If I don't; than it will get to 4-5k rpm before auto shifting.
After I changed my engine oil also the same thing.......so suspecting is clutch.......so anyone else could verify that??
hmmm... i think is gearbox problem leh or maybe the auto clutch thinggy...cos mine auto year 99 dun have this problem also.... normal auto car juz shift gear normal no matter the engine is cold or not....
Bro, it's 100% sure gearbox problem... In my case,
When starting in the morning, put to D, no gear masuk, have to put to L, then it engage 1st gear, run in L then shift to 2, 10% chance can engage to 2nd gear(for a few minutes or a few seconds), if not, the gear like shift back to N although you're in 2, have to slow down and shift back to L, repeat process or leave it in L until about 10 minutes until the gearbox warm up then ok...
I changed my gearbox, bro, your gearbox can RIP (Rest in Pieces as spare parts), auto tranny is very complicated and hardly fixed, mine sent to the mechy 2 times still cannot, even his shop is known as a auto tranny saviour... LoL, he reccomend me to change the whole gearbox, now ok2 liao...
fyi : My ride is a Wira 1.6
Mostly likely a failed pump. This one have to replace entire gearbox. M-Scope can fix any auto gearbox. I'm sending my spare to them for overhaul.
is a torque converter(clutch) failure, cant response properly when transmission oil is cold... i got tis problem b4, den i go find a 2nd hand and good condition torque converter and change it... it work good dy~ and i didnt change my gear oil cos i jus change~ i using castrol auto transmission oil...!!
btw, beware of auto transmission when flooding~ sum auto gear r not water proof, last time.. my R not function, i cant reverse... den i open my gearbox, my gear oil bcome muddy water ~.~ll lucky i go to repair it fast... if not, i nid to change whole gearbox
its torque converter inside alright.
it has multiple wet clutch inside like the one used in motor kapchai.
and most probably has burned. the oil pump is built internally and fixed because they would never failed - unless of course run without any ATF inside. otherwise, they are lubricated and no reason what so ever to fail.
