asking..
swap aka SWAP
wat t different
svt 1st gen gearbox =
svt 2nd gen gearbox =
bt gearbox =
if i wan to put trd or toda metal gasket to my svt 1st gen..is that same as 2nd gen..i`m afraid not same..
I think the 1st gen svt and 2nd gen svt is the 3rd and 4th gear ratio is different only. Just my 0.001cent lar.. ..
if you are talking about c52 and c56 gearbox then yes. i think i heard someone says first gen svt on c52 and 2nd gen on c56.. dunno if it is true or not lar.. me n00b on all gearbox beside a few fr gearbox.. -__-
all geabox u can use la..power already..y use metal gasket? playing really hi compression ka swap or got boost already? hehe..
any body can give me part num for trd metal gasket for svt 1st gen..it different from 2nd..i not playing boost...juz wanna try high comp...0.8mm gasket i think..not 1.4mm la..
TRD gasket only have 1 type .......... they didn't separate 1st or 2nd gen 1....
o ic...
but last time my friend order to me from Japan. when i still using svt. but i didnt put in svt. i put in black top. also can use.... all the thickness is 0.8mm is it..
where r u now
kilang ah
