ARP 4G63 Main Studs
ARP 4G63 Main Studs
silver_knight
MD Racing
When rebuilding an engine, there are several stock parts you wont want to reuse. Stock main studs stretch over time, and even more so each time they are re-tightened. Each time they stretch, their clamping abiltiy decreases. If mainstuds stretch, bearings can spin, and possibly even worse. Mainstuds are a low cost item that can mean the difference between your engine lasting, or not. Use ARP mainstuds for your engine build.
ARP uses a premium grade 8740 alloy that is rated far superior to "aircraft" quality. Then, each stud is heat-treated to 190,000 psi. Every ARP stud kit exceeds the most stringent aerospace specifications. All kits come complete with hardened parallel-ground washers and aerospace quality nuts.
Available For Evo 1-9 & vr-4 & 4G67
Price Rm360
Loc Shah Alam
call/sms/whatsapp
0182131320 -matt-
