Manley 4G63T EVO 1-9 Stroker Kit 2.3L
redmaf14
I have a set of 2 manley stroker kit for 4g63T platform. 1 unit of Evo 1-3 and another unit Evo4-9.
Both sets have similar specs. Comes with Piston 87mm 9.0:1 compression ratio, H-beam conrods and 100mm stroke forged crank.
The specs:
Conrod:
Manley "H" Beam connecting rods are manufactured from 4340 forgings to the same exacting standards developed and approved by our original equipment customers. There is a vast difference in quality between a Manley "H" Beam and the "other" inexpensive H-Beams on the market. Weight matched to +/- 1.5 grams. Perfectly round big and small ends. Bend and twist is tightly controlled. Cap fasteners are 3/8" ARP 2000
Piston:
Manley pistons are machined of high strength 2618 material. Each design is lightweight yet robust enough to deliver long service life. Offset wrist pin design is utilized for quiet start-ups. Perfect ring groove to skirt squareness is achieved through our unique "one fixturing" manufacturing method that assures maximum horsepower. All pistons come with moly coated skirts. Round wire locks, premium chrome moly wrist pins, and premium steel top ring sets from Total Seal are included with every kit at no additional charge
Crank:
Premium heat treated forgings
Special teardrop, diagonal oiling features not found on stock OEM style cranks
Better performance at High RPM
Stress Relieved & Shot Peened
Nitrided
100% Magnafluxed
if needed can be supplied together with full engine studs:
ARP Head Studs
ARP Main Studs
ARP Harmonic Balancer Bolt
ARP Mitsubishi 4G63 cam sprocket bolt
ARP Flywheel Bolt Set Mitsubishi EVO
FOC: Exhaust manifold studs and nuts
This studs and bolt package would cost RM1299 if bought together with the stroker.
Head gasket:
Power Enterprise 87mm bore 1.5mm thickness. This gasket is been used in many high horsepower(1000HP) cars and its very highly recommended. RM899
if cannot be reached by phone, pls just pm me.....il return ur message... overseas....
