Airtrek Turbo Wheel-hub bearing
biao
Hi Sifu,
did any one have change the wheel-hub bearing before?
how much the cost change the new one?
not airtrek...but other car...
just check what bearing code....buy bearing and sent the hub to machine shop if need pressing...
i guesstimate bearing for airtrek about rm130-240 for 1pcs depend on what type of bearing used...
can do like this? i saw the halfcut shop used unit is complete with hub and the 5stud together, bearing is conseal.
definately yes...
thats how bearing replacement is done...
depend on bearing type...
either this
or this type
the latter is much easier...just remove everything by screw/bolt and replace...
I prefer go workshop and ask them to exchange new bearing will do.
Front pair is around RM300-RM400, different brand different place price will different, i just change mine last month.
hi, our airtrek turbo is using which type? your foreman help you change which 1?
buy a bearing to press in replace or the whole wheel hub type?
I didnt not know, i leave to my friend to settle it.
They will take out from your car as sample, and find same size to fit in, about 1 day jobs only.
For vehicle using rear hub bearing assy such us toyota camry, the average cost to replace the part is between $400 – $500 for one side, labour between $100 – $200 for one side.
