Performance i dont know. Never try before those high cams. Still a beginner. But spec for Toda C2 and Briancrower stage3 only slightly different.how about the performance? did u survey the performance of these cam?
Wow.. thats great. Thanks.Most Japanese spec cams give normal idle when used. Even the higher levels like Toda C2 and Jun 3 can give idle like a stock car.
USDM cams like Skunk2, if level 1-2 give standard idle, if level 3 or more usually will not give smooth idle or good low end power for daily driving. Even skunk2 admits this on their website. Brian Crower also puts that information on their website.
Depends on what you want, you may want a race oriented cam, or a performance oriented cam. Most japanese cams are meant for street, so they're usually a bit milder than USDM cams.
There's no one good cam. Depends on setup and what you expect out of it. If stock standard, keep it as it is. The standard cams work quite well until you start increasing compression past 10.5-11.
I've never driven a car with a USDM cam, so I can't say performance wise if they're indeed better than Japanese cams. Seems like some SuperSixteen racers are using them succesfully, so that's at least one testament to their performance..
may i know who is using ek and eg?if you want change to high cam,make sure increase ur compression first...
Don't forget the valve train components. It'll say its compatible with factory valvetrain but I would 100% recommend changing to aftermarket valve springs and retainers coz we VTEC people tend to love going over the redline...
Skunk2 Pro Series Stage 2 < Toda C's in terms of top end
Skunk2 Pro Series Stage 2 > Toda C's slightly in terms of midrange
There was a dyno comparison back to back on these cams on a 1.9 liter motor in honda-tech. But they love the Toda C's performance compared to skunk2.
Question is: Which one is cheaper?
:proud:
What you guys think about this cams? Hardly seen its application here >>
Buddy Club Racing Spec V B-Series DOHC VTEC Camshafts
Specifications: intake 312 duration, 12.8 mm lift, exhaust 306 duration, 11.8 mm lift.
[FONT=Arial, Helvetica, sans-serif]Utilizing advance Japanese auto manufacture profile modeling Buddy Club has developed a versatile cam shaft that produces feasible horsepower, smooth idling and better throttle response over OEM through out the power band.
[SIZE=-1]Buddy Club Spec V Camshafts are made with brand new blank chilled cast cores to ensure strength and flexibility to take advantage of our patent pending Lobe Forming Technology to truly optimize the primary and VTEC cam lobes. The Spec III Plus camshafts were designed to accommodate a wide range of compression ratios from 10.0:1 to 13+. These cams are our most popular camshafts to date! They are designed to provde a smooth and constant power especially in the low and mid range areas and throughout the rest of the power band. These are ideal street camshafts for anyone who wanst some extra power to their engines.[/SIZE][/FONT]
- [FONT=Arial, Helvetica, sans-serif][SIZE=-1]Ideal for street use[/SIZE][/FONT]
- [FONT=Arial, Helvetica, sans-serif][SIZE=-1]Direct Bolt-On[/SIZE][/FONT]
- [FONT=Arial, Helvetica, sans-serif][SIZE=-1]Patent pending lob e forming technology for low to midrange torque[/SIZE][/FONT]
- [FONT=Arial, Helvetica, sans-serif][SIZE=-1]Provides smooth constant power throughout the power [/SIZE][/FONT]
where skunk 2 pro 3 will have better high end after pass 7k-9.5KRPMDon't forget the valve train components. It'll say its compatible with factory valvetrain but I would 100% recommend changing to aftermarket valve springs and retainers coz we VTEC people tend to love going over the redline...
EDITED:
Skunk2 Pro Series Stage 1 < Toda C's in terms of top end
Skunk2 Pro Series Stage 1 > Toda C's slightly in terms of midrange
