HAIYO!!!PENANG KIA nowadays damn lanci
sini lawan sana lawan, what for?
anywhere around malaysia with P plate all fxxking lanci tailgating action like in movie
this is what all chinese say KIASU (scared lose) sigh! what a culture!
SVT dragging a 205 tires, no need to worry la. NA vs NA won't be far off the scale.. 22nd you got go?
actually i m still facing the timing setting problem.. when i was about to rectify the problem.. my car kena bang by a lesen L motorbike.. damn stupid.. go against the traffic in a one way street.. repairing my car now... after that only can do setting.. but rev all the way to 8200, no prob, but power drop after 7500. may be setting problem.. i will keep u guys updated lah.....
sorry to hear that(the accident)...What ecu you use?May need to remove the rev cut.
Since you balance already,hope you use good main and con rod bearings as well as new con-rod bolts.Presume you mate it to a 6speed gearbox.
If this all done add 288/288 (other people have used 288 with vvt)cams higher duration but SAME lift;use 4-1 exhaust for higher end,lighten flywheel(cannot remember bolt patterns for flywheel between BT and 7AF same or not);maybe change final drive to 4.5 and this should pull 10k revs already.
Good luck!! and keep us updated
Eh... I thought 7AGE is not rev happy? Also, I don't see any reason why the rev cut should be removed since the powerband is expected to drop after 7000rpm.
Anyways, I think this link should be a good read for 7AGE enthusiast: The 5A and the 7A
On the other hand, 5AGE sounds just as interesting....
i think the RMP can rev till 9500.....1st gear of my 7a 20valve ever rev till 10000rpm....the power is really nice.....but in the end...my 4 piston ring all broken.....hahaha....
i really respect your courage, rev until 10k, but i got no money, cannot afford to keep changing engine.. hehe.... 7a is not meant for hi rev, maximum is only 8k rpm, anything beyond that is juz rev, and no power... dangerous also, coz that engine is not meant for hi rev..
anything beyond that is juz rev, and no power.....
WONG...u can find a 6 bolts manual flywheel in 4afe or 5afe.....i oso cant remeber too..but my 20valve last time using 7a bloack and blacktop head,but i can use back my VVT......walao....third gear really can feel very nice the power....
The power equation is as follows
Power(hp)= Torque X RPM
anyone who has dyno knows using lower gear gives higher torque reading.
So for NA increase compression and subsequently torque will increase power AND the other way is to increase USABLE RPM
Cheers!!
