bros n sifus,
plz advice me what to do to cure my engine from running lean, i just collected my car last sunday, and ask my fren to run in for me, but he notice from the wide band that the car is running very lean, at 16 - 17 :1,
different ppl say different things, so i need advice from those who know and successfully build a 7age 20v, this is the current situation, i m using stock bt injector n stock fuel pump, even regulator set at 4 bar, it is still running lean, there are conflict of opinion from few ppl,
1. change the fuel pump, 3SGTE or 1JGTE pump, set high pressure 3.5 bar
2. change injector to 1JGTE, set regulation at 2.5 bar
i am also confused as i know bt injector is 295cc which according to a lot ppl it is more than enough, but some say i need to change injector to a bigger one...
plz put your ideas and opinion,
thanx
thanx
