things you need to change are very common parts to change:
1) air filter
2) oil filter
3) fuel filter
4) water pump (optional)
5) clutch
6) hoses (optional)
7) brake pads
8) suspension (usually comes with half cut)
9) engine oil
10) gear oil
11) brake fluid
12) radiator water
13) power steering fluid
think that's about it i guess...feel free to add to the list :)
put hi-cam, adj pulley, valve spring...trumpet, new timing belt set...
overhaul...he he he oversize piston & ring...new bearing..metal gasket..etc...
bro nappx.....put poison ar?
14) timing belt
15) other belts (optional)
all the basic necessity ...wear and tear parts...
you shouldn't worry much if you've sent it to an experience workshop...
all you need to worry is...what's the next mod will be![]()
enjoy the new transplant...
drive safely ...
