4G9X/4G6X Gearbox , LSD and bla bla
jinkl
4,000 RPM
GearBox Code Vehicle Front LSD Ratio
W5M33-2-NGRE Lancer gsr RS (1992, 1800cc) ?
W5M33-2-NNZT Eclipse AWD 5spd mfg 3/94 ?
W5M33-2-NPXV 91-94 Eclipse AWD 5spd mfg 6/90-2/94 ?
W5M33-2-NPZT 95-96 Eclipse AWD 5spd mfg 3/94-6/96 ?
W5M33-2-NQBE Libero/Lancer Gsr, non lsd version of NRWE No 3.545
W5M33-2-NQBK 1991-92 to 4/92 VR4/ZR4 Galant ?
W5M33-2-NQBM 1992 Galant to 5/92 ?
W5M33-2-NRBE 92-95 Lancer GSR, lightweight synco's 2nd & 3rd No 3.545
W5M33-2-NRWE 92-95 Lancer GSR, stronger box, dbl syncro 2nd Yes 3.545
W5M33-2-NRXD 1990 Cyborg No 3.545
W5M33-2-UPFE Evo3 RS with front LSD Yes 3.909
W5M33-2-UPGE Evo3 GSR non LSD No 3.909
W5M33-2-UPWE Evo3 GSR with front LSD Yes 3.909
W5M33-2-UPYE Evo3 RS non LSD No 3.909
W5M33-2-WPFE Evo2 RS with front LSD Yes 3.909
W5M33-2-WPGE Evo2 GSR non LSD No 3.909
W5M33-2-WPVF Galant VR4 E84A ?
W5M33-2-WPWE Evo2 GSR with front LSD Yes 3.909
W5M33-2-WPYE Evo2 RS non LSD No 3.909
W5M33-2-WQFE Evo1 RS with front LSD Yes 3.909
W5M33-2-WQFK Galant VR4 evo ? ?
W5M33-2-WQGE Evo1 GSR non LSD No 3.909
W5M33-2-WQNK VR4 Evo, close ratio box ? No 3.909
W5M33-2-WQWE Evo1 GSR (and RS?) with front LSD Yes 3.909
W5M33-2-WQYE Evo1 RS non LSD No 3.909
how to check urs is LSD ?
you may see through the hole in the gearbox whether it is fully through or is it just halfway where a shaft is in the middle. if its through then its lsd
to check whether its aftermarket or stock lsd.
oem lsd need longer crownwheel shafts and driveshafts around 1inch longer
oem lsd is VISCOUS lsd and not MECHANICAL or CLUTCH type
aftermarket confirm uses back ur non-lsd driveshafts
it maybe clutch type , mechanical , helical , torsen or anything else
1-way engages only on acceleration
1.5way for acceleration and lil in deacceleration
2way goes for both
full lock is ALL TIME
usually POTONG ppl do mistake here, they think the oem lsd is FULL LOCK :) and they still do claim it as "Ini FULL LOCK LSD , special driveshaft punya"
W5M33-2-WQNK VR4 Evo, close ratio box ? No 3.909\
used this gearbox, it is a close ratio gearbox from VR4 ecimulti a.k.a vr4rs.
