many item too clear
many item too clear
takazz3
hello alll zth
- piston 1.8gti with conrod x 4 = RM200
- 4G93T turbo crankshaft = RM400
- 4G93 gti crankshaft =RM300
- GTI 1.8 camshaft x 2 = RM300
- Block 1.8 4g93(kosong) no surat = RM250
- engine 1.3 carburator complete = RM650
- Wiring GSR Turbo without ecu (from engine to ecu) = RM650
- coil ignition GSRT = RM250
- Distributor GSR T = RM200
- Disk brake 1.5 pair = RM100
- Disk brake 1.3 pair = RM50
- REAR DISK EVO sebelah shj complete disk n caliper = RM250
- Knuckle depan RVR 114.3 x 5 lug - pair = RM250
- Knuckle depan EVO 114.3 x 4 lug - pair = RM250
- Knuckle depan VR4 pnp saga, wira 114.3 4/5lug - pair = RM230
- Knuckle wira depan pcd 100 - pair = RM150
- Knuckle belakang evo123 114.3 - pair = RM150
- Head Evo 2 complete = RM500
- Piston evo2 x 4 = RM300
- Bonet blkg satria plat atas convert plate bawah siap bumper mivec n wiper motor = RM350
- side skirt 4g93t CK model = rm250
- bumper belakang evo3 with rearskirt = RM250
- Bumper depan lancer Gsr siap lip = RM200
- Dashboard Lancer complete with armrest = rm450
- Dashboard Wira 1.6 complete meter 240kmh auto = RM400
- Dashboard EVO 4 manual complete with armrest n gear console = RM950
- Signal evo oren pair = RM80
- aloy spacer 114.3 1" thickness japan made with build in center cone = RM250 pair
- MIVEC plug cover and Intake cover plastic = RM300
- MIVEC stock campully pair = RM120
- mmc ECU 5806 1.6soch = RM300
- MMC ECU 6247 2.0V6 = RM650
- GEARBOX HOUSING 1.5 SAGA WITH GEAR RATIO = RM200
- EVO1 DOWNPIPE STANDARD FROM TURBO TO EX = RM80
- intercooler supra = RM250
- Boost Meter SARD 2.5 bar EL blue = RM300
- Greddy meter piller ori japan = RM100
- Airflow 449 gsr = RM100
- Airflow 454 4G91 = RM100
- Airflow 455 putra = RM100
- Airflow 507 V6 = RM280
- cooling coil wira brand (sanden,patco,apm) - RM150 each
- Wira/lancer a/c blower - RM50 each
- radiator 1.3 - RM50
- A/c Condenser 1.3 - RM50
- monroe reflex 1.8 rear absober with apexi heavy duty spring - pair - RM300
- Evo3 4wheell front diffrentshell gearbox or anak gajah = RM300
- airfilter adapter 2"inlet local = RM30
- Airfilter adapter 4"inlet japan = RM80
013 275 3666
