4G92P jerking
So far, what I did:
- replace plug cable
- replace fuel filter
- clean MAF using CRC MAF Cleaner
- replace distributor with half cut one
Now, the problem is; when I press the acceleration pedal abruptly, is will be bad jerking. After a few moment, it will be normal again. For example, going into SmartTag lane with gear 2, after the toll, start to accelerate, then jerking happened and back to normal after some time. If I want to avoid the jerking, need to accelerate/pick up speed very slowly, cannot be abruptly. Anyone has experienced this kind of problem? Maybe the halfcut distributor gives problem, but when I first installed it, no problem happened... :hmmmm::hmmmm::hmmmm:
