g88 3,000 RPM Senior Member Aug 29, 2014 #1 Anyone know where to get this housing in klang valley area, its has extension to oil cooler. Doesn't matter new or used item as long its working.... Was told there is different between 1st and 2nd gen 4G63
DanzEterna Moderator Moderator Senior Member Aug 29, 2014 #2 should be identical with evo 1 2 3 right?
g88 3,000 RPM Senior Member Aug 29, 2014 #3 DanzEterna said: should be identical with evo 1 2 3 right? Click to expand... Identical but most halfcut either selling the one with no extension to oil cooler or there will go together with the full halfcut engine.... if this piece along, need to know where got sell and price......can any sifu help. 1st and 2nd gen 4G63 got little different....
^pomen_GTR^ 7,000 RPM Senior Member Aug 29, 2014 #4 better go with those normal oil-cooler adaptor sandwich...cheaper and easier to install...and added bling to engine when use with oil filter relocator type
ken yeang 6,000 RPM Senior Member Aug 31, 2014 #5 true, adapter is one alternative...provide there is enough clearance of space available
