ACL Race for 4G63
ACL Race for 4G63
silver_knight
MD Racing
* Designed to withstand higher RPM conditions.
* High strength overlay plate with reduced thickness for improved fatigue properties.
* Hardened steel backs on all rod bearings to improve the support of the bearing lining and assist with bearing retention in the housing.
* Increased crush for improved bearing retention.
* Elimination of flash plating on the back of the bearings to improve heat transfer through the bearing sand to maximize the grip between the bearings and its housing.
* Increased eccentricity to compensate for bore distortion at high rpm and to assist in the formation of hydrodynamic oil films.
* 3/4 grooved Main Bearings to optimize bearing load carrying surface area and oil flow to the conrod bearings.
* Tight consistent wall tolerances to help you maintain consistent clearances.
* Enlarged ID chamfers on bearing edges where required to accommodate large fillet radius on performance cranks
for 4G63/4G67 6 bolt vr-4 & evo 1 2 3...
new..
100% genuine product...
loc sek 27 shah alam..
call HDT for more info
018-2131320/[email protected]
