4G15 head skimming
WJR2001
How far i can go with skimmed 4G15 Head? i mean its HP increament? How much it can be skimmed?Do i have to change my extractor? current 4-1.
Skimmed head can tahan ka?
ok roger n out.
how many hp....veli sensative question....but u will get improvement definately. plus if u drive wt lite foot u can have a better fuel comsumption by head skimming
dun worry...juz skim da head till da max n if yo engine overheat juz remove da thermostat n get a biger radiator
but the temp will increase and need to check the engine water from time to time...
becareful on this... later engine gasket will say bye bye to you...
i skim mine.
performance is terrific.
need to get a professional to do it or else your valve will hit the piston head and become taugeh.
or else u can install high compression piston. it also gives u the power = skim head.
just my 2 cents only.
