4G15 With SuperTouring 8.5" Flywheel
WilsonTHarv
Hey there guys , have anyone use this combination on a 4G15 here ?
Just wanna get some opinion regarding this . As some said the flywheel should be skimmed as it is heavy , some said if skim will loss top speed ,i'm quite confused ...
Im using Clutch Pump Manual Box from Wira SE , can this gearbox use 8.5" clutch ?
Should i skim down the supertouring flywheel ? if yes how much weight i should target for ? it is intended to be daily driven .
Thanks for any advice from sifus here =)
