4AGE exhaust experiment report
corollagtouring
1st setup
1) Limit AXS 4-2-1 exhaust Manifold
2) 2.5 Inch piping
3) Apexi Megaphone Dunk Muffler with Limit AXS centre bullet
Result:
Engine feels very slow at low revs especially 1st 2nd and 3rd gear. Response or performance can be felt at 5k rpm above. tremendous top end power. climbs from 130km/h to 190km/h (and more) without hassle, a VTEC and Alfa (New model), Really sorry guys.....failed to tail me at high revs/gear but i was beaten easily at low revs/ gears...... but fuel consumption is higher and engien felt like struggling to accelerate... RM 10 per 65 km journey
Quiet at 5k rpm below
2nd setup
1) Fujitsubo Giken 4-2-1 exhaust Manifold
2) 2.0 Inch piping from manifold to fuel tank.
3) 2.5 Inch piping from fuel tank to muffler
4) No centre bullet
5) Apexi Megaphone Dunk Muffler
Result:
Engine climbs to 120km/h very fast, smooth response, 1st ,2nd to 4th are very enjoyable. But lost top end power, engine really have to put an effort to chase up to 180 km/h. But once the accelerator pedal is raised, the rev is "KEPT"..... rev doesn't drop quickly, it feel like the pedal is still stepped on. Fuel consumption is very good, not noticed but i think it is RM 10 for 97 km journey now.
2.5 for rear piping is to see whether it will help at 5th gear, it aids a bit.
Slightly increased level of sound, Quiet at a any revs but when the pedal is stepped on hard, there is a rattling sound produced.... WICKED......
Next setup (friend's car)
1) 2.0 piping
2) Apexi 4-1 Spiral Exhaust Manifold without centre bullet
3) Tanabe Muffler
- Waiting for results-
Take note that 4-1 Exhaust Manifold is for top end gains. Want to see whether the top end and acceleration can be balanced by this setup.
I think 2.3 inch piping is suitable for 4age users whom have done modifications to the internal of their engine. I have read in Jap mags that they are using 2.5 inch for max modded 4age (NA). Please correct me if I am wrong. Becos there is lack of info regarding what exhaust setup is suitable for 4AGE, i hope we could all give opinion from this thread.
Note: I am sorry if there is any wrong facts and i hope this will be a useful info for all of us.
Apexi N1 - Non JASMA Approved type.
2.38" Apexi pipes all the way with 2" tapered neck joint at Bullet entry and exit and Muffler entry. 1.8" Hollow Tapered muffler inner pipe. 100% from japan (the whole assembly) - The ultimate choice for 4A-GE
Annoyingly loud but NO LOSS and all gain from low rev to rev limit & no loss of fuel economy. Nuff said.
Apexi GT - Non Jasma Approved.
Full set exhaust system.
Very responsive, great for high RPM. Great for track application.
WARNING: Damn loud and very obvious size...use only you can bear the sound and willing to pay "Kopi Lui" to police.
stock standard except spiral bullet.
Result - worse fuel consumption and power. enaugh to said. I suspect it was installed wrongly as "terbalik" flow. Going to remove out and do not wan to use any bullet. Will update the result.
Coming mod - will be using 1.8" or 2" pipping all the way. stock extractor and muffler. Stock piping was 1.4" if i was not wrong.
Yup the only ones that can outperform Apexi N1 is Apexi GT & Apexi N1 Hayabusa. I suspect TODA N1 and HKS N1 (all Non JASMA approved) is oso good but never had a chance to try them out.
sound enhancement..."TRUMPETS" :shocked::shocked:
me using yoga ex cusco 4-1..fse fuel reg..hks filter..2 3/4 piping..big center bullet..apexi n1 muffler..the power 1 to 4 ok la..5th gear slow abit..fuel consump wa..high wo..fuel reg juz set to 40 psi..
swap
throw away that exhaust setup and go find apexi n1 full set and use with the cusco 4-1 ... GUARANTEE will be grinning from ear to ear ... :shades_smile:
ok..now who wan to sell to me full system of apexi n1 system..but muffler can be used back mine 1 kah yoga..for corollatouriing how come u can get 97km for rm10 petrol..u never tekan ur car meh..i think my ex gze petrol even better..but last time my gze juz oem la..yoga..i juz use svt so wat the good setup..
gila kaa 2 3/4 inch piping ??? almost turbo car specs liau that one .. hehehehe .. no wonder laa no power at high end ... your 4A cannot suport so much "empty space" to fill laaaa ... hahahaahahahahahaaa
anyways ... 2 1/4 inch sound good enuff laa ... N1 rear muffler ... centre change back from the BIG SHIT to a medium size one (almost like N1 resonator) ... u should do well liauu laaa ... no need to spend too much ... hehehehe
as for 5th gear ... biasa laa 4A 5th gear no power (stock stock) laaa .. unless u go change the gear ratios or final drive or do something drastic to your engine .. 5th gear will never have power one ... hehehehehe
so sifu..really ka..if stock eng juz mod ekzos only the 5th gear really slow..when inside car have 4 ppl..heavy ppl la..when 5th gear from rpm 3k wan reach to 6 k also sakit wo..
4AGE is a high revving engine laa ... all the power can only be produce from high revving ... that is above 5k RPM ... if u want low end power then use back 4AFE better but u dont get high end laa of coz .. hehehehe
use 4th gear tarik kow kow until rev cut only change to 5th lorrr ... then 5th at least feel like can go abit laaa .. hehehehe
my engine which has much more torque than your 4A with 4 ppl inside the car oso susah to climb up so easily laaaa on 5th ... :p
errr .. my car not blktop oso laa .. hehehehe
btw ... blktop and svtop power not that much diff laaaa ...
