WTA:ST with BT wiring
olskool
Hi All,
Apologies if this question have been asked before but i can't seem to find it in other threads..
Currently converting ST 5mt to BT 5mt wiring and ecu...
Is there anything important or tricks to make the blacktop wiring work on a silver top? Is it a direct transfer?
So far I've only heard of rerouting of the vacumm hose...
Is there anything else that must be done for it 2 work?
Thanks in advance!:driver:
Engine Harness Connectors
Blacktop Project - Body Harness
Hi All,
svt to bt should be direct conversion, if you wanna kahwin wiring, i know few who can do it, but better use the full wiring... coz safer, one more thing you need to know, there is a socket that is connecting to the dashboard, the right one if not mistaken. is different between bt n svt manual, you need to find the socket, or if you r using svt auto, then should be no problem.
Thanks bro Scott..
I got the wiring as per below pic...is it possible to indentify which socket are you refering to? Thanks.
http://www.zerotohundred.com/newforums/attachments/engine-and-performance/244809d1253205403-ae111-4age-manual-engine-wiring-with-ecu-resize-of-image1407.jpg
Bro Scott, do you happen to know where does the wires go to? The one you mentioned that has the 3 socket..
