X1R Engine Treatment
Car Culture
Sunfly Accessories
X1R is a highly concentrated Advanced Engine Treatment and friction reducer
additive that works with all synthetic and semi-synthetic and mineral engine oils.
Here’s what our engineers will tell you:-
Discover what NASA already know and find out why winning racing drivers around the world have switched to X-1R’s proven technology. Across the USA millions of drivers have already discovered the benefits of using X-1R and that’s because we deliver a full range of performance enhancing lubricants that keep engines running smoother and longer. Use X-1R just once and you will quickly notice an increase in engine power (Elliot Bros Racing Team) and experience improved fuel economy (ASME verified) whilst reducing wear significantly (Oakland U.)
Safe and easy to use:-
X-1R Engine Treatment is designed for use in all types of vehicles, all you need to do is pour into your engine and go, no oil change is necessary. Immediately you will notice an improvement in the efficiency of your vehicle. But what’s more X-1R Engine Treatment is non-hazardous, non-flammable and proven to be environmentally friendly.
Directions for use
X-1R Engine Treatment can be added at any time, however, for optimum performance we recommend you use when you next change your oil. For average size cars, RV’s, 4WD, high cc motorbikes and light trucks simply add the contents of one bottle to you oil (vehicles with up to 5 litres oil capacity). With higher oil capacities we recommend that you use X-1R Engine Treatment at 5% to volume of oil.
Users would definitely feel the difference in their vehicles performance almost instantaneously upon using X1R.
X1R gives you:
- Noticeably Smoother & Quieter engine
- Increase Horsepower & Torque
- Improve throttle response
- Substantially reduce engine drag, friction and vibration
- Better fuel consumption
- Protects during cold starts
- Reduces operating temperature
- Substantial reduction in engine wear
- Reduces engine noises and vibrations
- Compatible with all engine oils
COD available at Puchong Jaya.
Pos Laju available @ additional charges within Malaysia.
Price:
1 Bottle @ RM52
2 Bottles & above @ RM 51/ bottle
Contact:
0166393253/ 0146254549 (Watsapp & Viber available)
X1R Videos : http://www.x1r.com.my/Videos_14_1.htm
X1R Ultimate Test : X-1R and the Airplane test - YouTube
