[WTS] Wrenches (Accessories)
150 pcs 1/2'',3/8'' x 1/2'' DR Socket Wrench Set
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/s/a/sata_socket_wrenches_set_09510-1a.png
( Metric & S.A.E )
Description :
1/4" Dr. 6pt. Metric Sockets 10pc - 4, 5, 6, 7, 8, 9, 10, 11, 12, 13mm
1/4" Dr. 6pt. S.A.E. Sockets 10pc - 5/32", 3/16", 7/32", 1/4", 9/32", 5/16", 11/32", 3/8", 7/16", 1/2"
1/4" Dr. Metric Deep Sockets 6pc - 4, 5, 6, 7, 8, 9mm
3/8" Dr. 6pt Metric Sockets 11pc - 9, 10, 11, 12, 13, 14, 15, 16, 17, 18,19mm
3/8" S.A.E. Sockets 9pc - 3/8", 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", 13/16", 7/8"
3/8" Dr. Metric Deep Sockets 6pc - 10, 11, 12, 13, 14, 15mm
3/8" Dr. Spark Plug Sockets 2pc - 16, 21mm
3/8" Dr. Bit Sockets 22pc -
Slotted: 4, 5.5, 6.5mm
Philips: #1, #2,#3
Pozidriv: #1, #2.3#
Torx: 20, 30, 40,45, 50, 55, 60 (Tamper Proof Torx)
Hex: 3, 4, 5, 6, 8, 10mm
3/8" Dr. E-Torx Sockets 8pc - E8, E10, E11, E12, E14, E16, E18, E20
1/2" Dr. 6pt. Metric Impact Sockets 4pc -17, 19, 21, 23mm
1/2" Dr. 12pt. Metric Sockets 7pc - 20, 21, 22, 24, 27, 30, 32mm
1/2" Dr. 6pt. S.A.E. Sockets 4pc - 5/16", 1", 1-1/16", 1-1/4"
1/2" Dr. 6pt. Metric Deep Sockets 6pc- 10, 12, 13, 14, 17, 19mm
Accessories 23pc:
1/4", 3/8", 1/2" Dr. Quick-Release Ratchets
1/4'' Dr bit Coupler
1/4" Dr. Spinner Handle
1/4" Dr. Wobble Extension Bars 4"v 3/8" Dr. Wobble Extension Bars 3", 6"
1/2" Dr. Wobble Extension Bars 5"
1/2" Dr. Wobble Extension Bars 10"
1/4", 3/8", 1/2" Dr. Unversal Joints
1/4" Shank Torx Bits ( Tamper Proof ) T10, T15, T20, T25, T27, T30, T40
Hex Key Metric Set ( 10PCS)
Combination Wrenches 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19mm
Double Box Ratcheting Wrenches : 8 X 10, 12 X 13, 17 X 19mm
http://www.maswaretools.com/150-pcs-1-2-3-8-x-1-2-dr-socket-wrench-set.html
3pcs Double Ratcheting Combination Wrench
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/3/f/3fe18873-ea0f-4b20-9d67-56d42d884086.jpg
- 43203 - Gear Wrench 10mm
- 43206 - Gear Wrench 13mm
- 43210 - Gear Wrench 17mm
http://www.maswaretools.com/sata-3pcs-double-ratcheting-combination-wrench.html
Sata 11 pc Gear Wrench & Adapter Set
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/8/c/8c4cc41a-0b24-4e88-9f84-dd9eee1c083f.jpg
( 8/10/11/12/13/14/17 & 19mm)
Adapter - 1/4'' DR X 10mm / 3/8'' DR X 13mm / 1/2'' DR X 19mm
http://www.maswaretools.com/sata-11-pc-gear-wrench-adapter-set.html
P&M Torque Wrenches Model 633A
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/6/3/633a_1.jpg
Model 633A
Description : Torque wrenches 17, 22, 24, 26, 27, 29 mm wrenches
•17mm wrench : [Dimension] 1/4'' [Refrigerante] Conventional torque wrench + R410A
•22mm wrench : [Dimension] 3/8'' [Refrigerante] Conventional torque wrench + R410A
•24mm wrench : [Dimension] 1/2'' [Refrigerante] Conventional torque wrench
•26mm wrench : [Dimension] 1/2'' [Refrigerante] R410A
•27mm wrench : [Dimension] 5/8'' [Refrigerante] Conventional torque wrench
•29mm wrench : [Dimension] 5/8'' [Refrigerante] R410A
http://www.maswaretools.com/p-m-torque-wrenches-model-633a.html
P&M Reversible Ratchet Wrench Model 122
http://www.maswaretools.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/1/2/122.jpg
Model 122
Description : Reversible ratchet wrench
Capacity : Square opening with 1/4'' and 3/16'' at one end, 3/8'' and 5/16'' at another end
http://www.maswaretools.com/p-m-reversible-ratchet-wrench-model-122.html
