https://www.zerotohundred.com/forums/attachments/519740.vB
https://www.zerotohundred.com/forums/attachments/519741.vB
https://www.zerotohundred.com/forums/attachments/519742.vB
Dealing Method : COD
Contact : PM
Model: C-7.4T
Channels: 4 CH
Frequency Response: 20Hz ~ 20KHz ±1dB
Rated Power: 14.4 Volts DC
T.H.D.: < 0.1%
Pre-Amp Tube: 12 AT7 x 2
Driver Tube: 2 BH7 x 2
4 ohm RMS: 100W x 4
2 Ohm RMS: 150W x 4
S/N Ratio: > 105dB
CH Separation: > 70dB
Input Sensitivity: 1 ~ 10 Volts
Turn-On Time: Approx. 10 sec.
Fuse Requirement: 100 Amp External
Tube power Supply: 250 Volts
Power Supply: 11 ~ 16 Volts DC
External Cap Input: No
Dimensions: (L x W x H): 21 5/8" x 10 13/32" x 2 1/16"
Weight: 19 1/2 lbs. / 8.9 Kg
Contact : PM
Model: C-7.4T
Channels: 4 CH
T.H.D.: < 0.1%
4 ohm RMS: 100W x 4
2 Ohm RMS: 150W x 4
S/N Ratio: > 105dB
