[WTS] Philips Lighting Products
Kent_Goh
Philips Day Running Light
In response to the existing DRL (Daytime Running Lights) regulation, Philips LED Daytime Lights anticipate the coming European directive.* Committed to safety, Philips LED Daytime Lights offer a new lighting experience in daytime driving.
Philips LED Daytime Lights offer the simplest plug & play daytime lighting solution on the market with the driving safety you need and the contemporary look you wished for!
Benefits & Features:
Easy-fit
- Simple-click installation in less than 2 hours with basic tools
- Simple installation instructions supplied
- Ultra-slim design fits most European car models
Optimized high-power LUXEON® LED
- Projects a powerful bright white light
- Optimized energy consumption
- Lasts car’s lifetime**
Automatic on/off switch
- LED lights turn on automatically at the start of the engine, and turn off when parking lights are turned on
*Recent European DRL directive (2008/89/EC) requires that all new cars models from February 2011 have lights that switch on automatically during the day. To improve driver safety, many European and Scandinavian countries have already implemented compulsory DRL with significant accident reduction.
*Car's lifetime = 5000 h or 250 000 km at an average speed of 50 km/h.
4 LED - Rm500.00/Pair
5 LED - Rm550.00/Pair
8 LED - Rm650.00/Pair
Blue Vision (4000K) - The White Light Of Performance Bulb
- The Original and Leading choice in blue bulbs
- Produces a whiter Xenon type of light for the best reflection from road markings and signs
- Lasts up to 3 times longer than other blue bulbs in the market
Philips Blue Vision (4000K)
H1 - Rm120.00/Pair
H3 - Rm120.00/Pair
H4 - Rm120.00/Pair
H7 - Rm140.00/Pair
H8 - Rm160.00/Pair
HB3 - Rm150.00/Pair
HB4 - Rm150.00/Pair
H11 - Rm185.00/Pair
W5W - Rm25.00/Pair
Philips Blue Vision Ultra (4000K Xenon Ultimate Effect)
H1 - Rm130.00/Pair
H4 - Rm130.00/Pair
H7 - Rm150.00/Pair
Silver Vision (4000K) - Design solution for transparent optics
- 100% design, completely in tone with the silver reflector
- 4000K light output, stylish yet provides outstanding light performance
- Fully compliance with ECE R37
- Easy installation (no wiring or relays needed)
Philips Silver Vision (4000K)
Silver Vision (Signal Light) PY21W - Rm80.00/2pcs
Silver Vision (Signal Light) WY21W - Rm80.00/2pcs
Silver Vision (Side Signal Light) WY5W (Orange) - Rm35.00/2pcs
Silver Vision (Park Light) W5W (Blue) - EOL
Crystal Vision (4300K) - Stylist super white light
Suitable for all weather conditions with added visual comfort enhancing driving concentration during driving at night time.
Characteristic:
A unique blue filter creates the distinctive white light.
Halogen bulbs with UV Block Quartz glass that eliminates harmful UV rays thereby protecting plastic headlamps.
Application:
It is suitable for all cars fitted with Halogen bulbs and aimed at giving extra performance and safety in bad weather conditions. Every product is an OE product and will out-perform other generic manufacturers like an OE product should.
The leading choice in blue bulbs.
- Produces a whiter Xenon type of light for the best reflection from road markings and signs.
- Lasts up to 3 times longer than other blue bulbs in the market.
Philips Crystal Vision (4300K)
H1 - Rm170.00/Pair
H3 - Rm170.00/Pair
H4 - Rm170.00/Pair
H7 - Rm190.00/Pair
H8 - Rm250.00/Pair
H11 - Rm205.00/Pair
HB3 - Rm200.00/Pair
HB4 - Rm200.00/Pair
Diamond Vision (5000K) - Ultimate bluish-white light
The ultimate upgrade for your vehicle stylish outlook at night.The ultimate performance bulb with a color temperature of 5000K,absolutely blueish white,with the low output 60/55w its produce less heat and long lasting compare with others aftermarket white bulb,u can use back your original head lamp cable without add on wiring kits and relay
- 5000K light output, similar to daylight
- Blue reflection remain in headlamp reflector even when turned off
- Sae consumption rate as standard halogen
Feature:
- UV block quartz glass used
- High color temperature output
Applications:
- Directly interchangeable with originally equipped products
Benefits:
- Ultimate blue with 5000K dazzling white daylight output
- Provide total protection for headlamp reflector
Philips Diamond Vision (5000K)
H1 - Rm220.00/Pair
H3 - Rm220.00/Pair
H4 - Rm220.00/Pair
H7 - Rm240.00/Pair
H8 - Rm270.00/Pair
H11 - Rm280.00/Pair
HB3 - Rm250.00/Pair
HB4 - Rm250.00/Pair
Philips Power 2 Night GT-150 (3500K) - Maximum performance for safer driving
Philips have developed this outstanding new Power 2 Night bulb. By taking the plus 50% vision qualities of the Vision Plus bulb and adding a stylish blue tint they have a recipe for success!! This is the first bulb to legally combine the plus 50% vision quality and the ever sought after blue tint.
Philips are well known for producing products of the highest quality. These Power 2 Night bulbs are made from Quartz glass which gives them more durability than a standard bulb. The GT-150 is a must have for anyone wanting the highest quality upgrade bulb.
Benefits
- 50% more light output
- Produces a crisp light which is closer to daylight meaning better performance and less risk of eye strain and fatigue
- Highest quality and reliability
- UV protected and suitable for use in plastic lenses
- Fully E marked and road legal
Philips Power 2 Night +50% brightness (3500K)
H1 - Rm100.00/Pair
H3 - Rm100.00/Pair
H4 - Rm100.00/Pair
H7 - Rm110.00/Pair
H11 - Rm180.00/Pair
HB3 - Rm120.00/Pair
HB4 - Rm120.00/Pair
PHILIPS X-treme POWER +80% light 25m longer beam
Introducing the new world champion in high performance headlamp upgrades. Philips X-treme Power bulbs deliver up to an astounding 80% more light than standard halogens, yet they're fully road legal and come with the same quality and performance put into the lighting Philips sell to OEMs around the world. X-treme Power is a new "must-have" for tuners and high performance drivers.
Feature:
- These bulbs use a Xenon gas filling to increase the light output while being 100% legal and safe to use without any wiring upgrades.
- Ultra-Violet Cut glass, providing protection for Plastic Headlight lenses.
- Up to 80% more light on the road and 25m longer beam than original bulbs makes X-tremePower the best choice for upgrade vehicle lighting.
- X-treme Power (Extreme) is a new 'must have' for motoring enthusiasts and high performance drivers providing a crisp, xenon light.
- X-treme Power by Philips is the new champion in headlamp upgrades, they are fully legal and are made to original equipment manufactuer high standards meaning you get quality bulbs!
- Original equipment quality and fully compliant with R37 requirement.
- Compact filament - new design for the best lighting performance
- Chromium top - for perfect match in the car headlamp
Click >HEREb] for comparing of X-treme Power and stock light
H1 - Rm180.00/Pair
H4 - Rm180.00/Pair
H7 - Rm190.00/Pair
HB4 - Rm200.00/Pair
PHILIPS X-treme Vision +100% light 35m longer beam
Introducing the new world champion in high performance headlamp upgrades. Philips X-treme Vision bulbs deliver up to an astounding 100% more light than standard halogens, yet they're fully road legal and come with the same quality and performance put into the lighting Philips sell to OEMs around the world. X-treme Vision is a new "must-have" for tuners and high performance drivers.
Feature:
- Up to 100% more light on the road and 35m longer beam than original bulbs makes X-tremePower the best choice for upgrade vehicle lighting.
H1 - Rm200.00/Pair
H4 - Rm200.00/Pair
H7 - Rm220.00/Pair
Philips HID conversation kits
Philips Xenon HID lights are the brilliant, blue/white lights that first appeared on luxury and high performance cars and are now becoming available on an entire range of cars, trucks and SUVs. HID lights provide twice the light of conventional halogen lights for the ultimate in driving safety.
Philips is the world leader and innovator in the design, development, and production of Xenon HID lighting.
300% more lumen output than standard halogen bulb
With twice the amount of light you can see potential obstacles much sooner. At highway speeds, HID lights give you up to a full second more time to safely react to road hazards.
Feature:
- Highest light output
- Precise light distribution
- Brilliant "daylight" white light
- H4 with high beam as well as low beam for complete upgrade
Philips Xenon HID Bulb & Ballast (Original OEM)
Philips Xenon HID D2S 4200K - Rm900.00/pair
Philips Xenon HID D2R 4200K - Rm900.00/pair
Philips Xenon HID D2S 6000K - Rm1100.00/pair
Philips Xenon HID D2R 6000K - Rm1100.00/pair
Philips Xenon HID D1S 4200K - Rm1600.00/pair
Philips Xenon HID D1S 6000K - Rm1800.00/pair
Philips Xenon HID D4S 4200K - Rm1000.00/pair
Philips Xenon HID D4S 6000K - Rm1200.00/pair
Philips Xenon HID Ballast D2R & D2S - Rm950.00/pair
Philips Xenon HID Ballast D4S - Rm1050.00/pair
Philips HID conversion kit (Bulb + Ballast)
Philips HID conversation kits H1 4200K - Rm1400.00/set
Philips HID conversation kits H4 4200K - Rm1700.00/set
Philips HID conversation kits H7 4200K - Rm1400.00/set
Philips HID conversation kits HB4 4200K - Rm1500.00/set
Philips HID conversation kits H11 4200K - Rm1600.00/set
Philips HID conversion (Bulb Only)
Philips HID conversation kits H1 4200K - Rm600.00/set
Philips HID conversation kits H4 4200K - Rm900.00/set
Philips HID conversation kits H7 4200K - Rm600.00/set
Philips HID conversation kits HB4 4200K - Rm700.00/set
Philips HID conversation kits H11 4200K - Rm800.00/set
Philips HID conversation kits H1 6000K - Rm1500.00/set
Philips HID conversation kits H4 6000K - Rm1800.00/set
Philips HID conversation kits H7 6000K - Rm1500.00/set
Philips HID conversation kits HB4 6000K - Rm1600.00/set
Philips HID conversation kits H11 6000K - Rm1600.00/set
Philips HID conversation kits H1 6000K - Rm800.00/set
Philips HID conversation kits H4 6000K - Rm1100.00/set
Philips HID conversation kits H7 6000K - Rm800.00/set
Philips HID conversation kits HB4 6000K - Rm900.00/set
Philips HID conversation kits H11 6000K - Rm900.00/set
Philips Conversion Electronics (Ballast Only)
Ballast Conversion Electronics (Thick) - Rm880.00/pair
*Price might change without notification, kindly contact us thru SMS/Whatsapp 019 - 266 8138 or E-Mail [email protected] to check price, dealing method, product inquiries & technical issue. This is to ensure better tracking and a more efficient follow up. Thanks for your cooperation & understanding. Also, shipping & installation service provided with extra charges, please provide us your mailing address for shipping charge. TQ
*****Kindly leave me an message if i didn't pick up your call so that i can get back to you.*****
Regards,
XD-Autoparts - KentGoh
Website: www.xd-auto.com
Contact Person: KentGoh
Contact Number: 019 - 266 8138 (Prefer SMS)
E-Mail: [email protected]
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Shipping Service: Please provided your mailing address. (Peninsular & East Malaysia)
Facebook Page: Facebook.com/xdautoparts
bro kent u got the day light light wan?
i remember its from philips
pm mi if u got it
thanks
bro do u hav philips led day light?
which can in pairs.. got 8led per piece wan
pm mi thanks
pm me cefiro A31 bulb size H3C for all design philips bulb pls....very2 need that bulb asap..
Dear Bro,
Philips X-treme Power got HB4? what is the price? Got warranty?
Bro, these bulbs JPJ approved? (PHILIPS X-treme POWER +80% light 25m longer beam)
if confirmed yes, pm me please. btw, need to install relay?
Yes, Philips performance series bulb such as Power2Night, Xtreme Power & Xtreme Vision are all legal on road with no wiring add & modified. Just plug & play. Quotation sent, thanks for viewing
Hi,
How much fog light bulb(white light) for Nissan Sentra GXE 1.8 2001 ? The best price please.
And what is the bulb type?
Quotation sent, thanks for inquiry XD-Autoparts =]
Kindly contact us thru SMS 016 - 337 3368 or E-Mail [email protected] for fast deal or products inquiry & technical issue. This is to ensure better tracking and a more efficient follow up as i'm using blackberry. Thanks for your cooperation & understanding.
