[WTS] Pennzoil Platinum Series
Kent_Goh
PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-30
Pennzoil Platinum series is 100% synthetic motor oil with special protective additives for ultimate level of engine protection that meets API SM/CF standards. PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-30 MOTOR OIL is designed to provide protection under the most severe driving style or conditions. It contains a unique blend of highly refined synthetic base oil coupled with a propriety additive package. This special combination creates a superior layer of lubrication defending your hard-working engine and helping to protect it against wear generated by heavy loads, extreme temperatures and severe stop-and-go driving. PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-30 MOTOR OIL has been formulated with 100% synthetic base oil and additives that provide the best lubricant for today's high performance engines. This scientifically engineered synthetic base that makes these oil superior. In other words, it built better motor oil from top to bottom, using tougher materials. That is why PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-30 MOTOR OIL stand up to the most rugged industry standards for the extreme driving demand today's consumers place on their vehicles.
Benefits:
- Time-released molecules continuously lubricate, cool, and clean and creating a cushion of protective lubrication against extreme high engine temperatures caused by stop-and-go driving and short trips.
- PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-30 MOTOR OIL gives ultimate protection with superior anti wear protection and consistent engine performance.
- Provides ultimate level of protection against high-temperature deposits that can harm your engine.
- Fast lubrication at extremely low temperatures making start-up easy and less draining on the battery.
- Molecular uniformity of synthetic formulation to maintain viscosity, for easier start-ups, even in extreme weather conditions (hot and cold).
- Superior resistance to shearing under heavy loads to keep your engine running stronger and longer.
Recommendations
- PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-30 MOTOR OIL is recommended for cars and light trucks with petrol and diesel engines where API SM/CF are specified.
- Exceeds API SM/CF service classification.
- Always consult your owner's manual for the correct viscosity choice.
Pennzoil 100% Synthetic 5w/30
Rm135.00/4Liters
Rm720.00 for 6 Bottle
PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-40
Pennzoil Platinum series is 100% synthetic motor oil with special protective additives for ultimate level of engine protection that meets API SM/CF standards. PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-40 MOTOR OIL is designed to provide protection under the most severe driving style or conditions. It contains a unique blend of highly refined synthetic base oil coupled with a propriety additive package. This special combination creates a superior layer of lubrication defending your hard-working engine and helping to protect it against wear generated by heavy loads, extreme temperatures and severe stop-and-go driving. PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-40 MOTOR OIL has been formulated with 100% synthetic base oil and additives that provide the best lubricant for today's high performance engines. This scientifically engineered synthetic base that makes these oil superior. In other words, it built better motor oil from top to bottom, using tougher materials. That is why PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-40 MOTOR OIL stand up to the most rugged industry standards for the extreme driving demand today's consumers place on their vehicles.
Benefits:
- PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-40 MOTOR OIL gives ultimate protection with superior anti wear protection and consistent engine performance.
Recommendations
- PENNZOIL PLATINUM™ 100% SYNTHETIC SAE 5W-40 MOTOR OIL is recommended for cars and light trucks with petrol and diesel engines where API SM/CF are specified.
Pennzoil 100% Synthetic 5w/40
Rm135.00/4Liters
PENNZOIL PLATINUM™ SEMI-SYNTHETIC SAE 5W-30 Motor Oil
Pennzoil Platinum Semi Synthetic with the ultimate protection is formulated to provide extra protection for pure performance and new engine designs to overcome the demands of engines operating under hot climates and severe driving cpnditions. Pennzoil Platinum Semi Synthetic offers excellent anti-wear protection, consistent engine performance and improve fuel efficiency.
Pennzoil Platinum Semi Synthetic meets the requirements for gasoline and diesel engines when SAE 5W30 is recommended and surpassed the engine protection requirements of API SM/CF and ILSAC GF-4 service classifications.
Suitable for North American, European, Japanese and Asean vehicles when SAE 5W-30 are required.
To give added protection and life to your engine, use Pennzoil as recommended by your original equipment manufacturer (OEM).
Pennzoil with time-released molecules
All Pennzoil motor oils are formulated with time-released molecules, providing a sustained level of superior protection. These anti-wear addictives trap and remove the corrosive by-products of engine combustion. After doing their job, more addictives surface to ensure that your engine's moving parts-hundreds of them-are protected from friction, oxidation and extreme temperature.
Pennzoil Platinum Semi-Synthetic 5W-30
Rm90.00/4Liters
PENNZOIL PLATINUM™ SYNTHETIC BLEND SAE 10W-40 Motor Oil
Pennzoil Platinum Semi Synthetic SAE 10W-40 Motor Oil with Active Cleansing Agents continuously helps prevent dirt and contamination from turning into performance robbing deposits. This help to keep engine clean thus maintaining its responsiveness. It provides extra protection for engine under all temperatures and extreme driving conditions.
Applications:
- Semi Synthetic oil that is suitable for use in fuel injected, turbocharged, naturally aspirated and multi-valve passenger car engines that run on leaded and unleaded fuels.
- Suitable for all American, European and Japanese vehicles either with petrol or diesel engines.
Benefits:
- Pennzoil with Time-Released Protection. All Pennzoil motor oils are formulated with time-released molecules, providing a sustained level of superior protection
- Exceeds API SM/CF specifications
- Actively keeps engine clean
- Excellent wear protection
- Excellent engine performance
- Excellent protection against the formation of sludge during low temperature and short–trip driving Ultimate protection against viscosity breakdown
- Excellent protection for hot and cold running engines in stop-and-go driving
Rm90.00/4Liters
*Price might change without notification, kindly contact me to confirm the price. TQ
*Please Inquiry / Order by E-mail
Website:
www.xd-auto.com
Contact No.: KentGoh - Digi 6 - 337 3368
E-Mail: [email protected]
Shop Location: Kepong Jaya Jusco
Installation & Tuning: Kepong Jaya Jusco
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Lunch Time: 1.00pm - 2.00pm
Delivery Service: 11.00am - 6.00pm (Monday - Saturday)
Our shop:
Win Hong Auto Trading Sdn Bhd
No.153, Jalan Besar Kepong, 52100 K.L
Maps: http://wikimapia.org/#lat=3.2139519&lon=101.6382739&z=18&l=0&m=m&search=win hong auto
Dear All Members and Forumers,
I would appreciate if you guys kindly DO NOT PM/Call to me especially on XD-Autoparts related Products, Quotation, Technical Issues and etc.
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368. This is to ensure better tracking and a more efficient follow up.
Thank you for understanding, cheers.
Regards,
KentGoh
Engine Performance & Compartment
ASR Silicone Hose - http://www.zerotohundred.com/newfor...s-asr-silicone-hose-products.html#post4121197
Auto Service & Replacement Parts - http://www.zerotohundred.com/newfor...cement-and-performance-parts.html#post3858120
Bardahl Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341331-wts-bardahl-fully-5w30-and-5w40-rm85.html
Bosch Fusion Spark Plugs - http://www.zerotohundred.com/newfor...ance/237425-wts-bosch-fusion-spark-plugs.html
Bosch Type-R Oil Filter - http://www.zerotohundred.com/newfor...mance/244853-wts-bosch-type-r-oil-filter.html
Chemlube Lubricants - http://www.zerotohundred.com/newfor...chemlube-100-syncthetic-with-ester-based.html
Cold Air Intake Hose - http://www.zerotohundred.com/newforums/engine-and-performance/234747-wts-cold-air-intake-hose.html
Exedy Clutch - http://www.zerotohundred.com/newfor...ce/341326-wts-exedy-clutch-and-fly-wheel.html
Forged Racing Radiator - http://www.zerotohundred.com/newforums/engine-and-performance/362689-wts-forged-racing-radiator.html
Pivot Products - http://www.zerotohundred.com/newfor...223310-wts-genuine-pivot-raizin-products.html
Haydens ATF Cooler - http://www.zerotohundred.com/newfor...-hayden-transaver-all-weather-protection.html
Denso Iridium Spark Plugs - http://www.zerotohundred.com/newfor...nce/303916-wts-denso-iridium-spark-plugs.html
K&N High Flow Filter - http://www.zerotohundred.com/newfor...-n-high-flow-drop-in-and-open-pod-filter.html
Motul Lubricants - http://www.zerotohundred.com/newfor...ance/223342-wts-motul-lubricant-products.html
Pennzoil Lubricants - http://www.zerotohundred.com/newfor...ance/341332-wts-pennzoil-platinum-series.html
Q8 Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341333-wts-q8-lubricants-products.html
Redline LCP - http://www.zerotohundred.com/newforums/engine-and-performance/322721-wts-redline-lightening-crank-pulley.html
Hot InaZma Products - http://www.zerotohundred.com/newfor...-products-hot-inazma-hot-earth-hg-pocket.html
Torco Lubricants - http://www.zerotohundred.com/newfor...41337-wts-torco-sr-1-and-sr-5-lubricants.html
Works Air Intake System - http://www.zerotohundred.com/newfor...-wts-works-engineering-air-intake-system.html
Works Cam & Crank Pulley - http://www.zerotohundred.com/newfor...s-works-engineering-cam-and-crank-pulley.html
Works Drop In Filter - http://www.zerotohundred.com/newfor...724-wts-works-engineering-drop-in-filter.html
Works Fuel System - http://www.zerotohundred.com/newfor...341343-wts-works-engineering-fuel-system.html
Works Magnetic Oil Sump Nut - http://www.zerotohundred.com/newfor...-works-engineering-magnetic-oil-sump-nut.html
Works Oil Cooler - http://www.zerotohundred.com/newfor...ering-oil-cooler-engine-and-transmission.html
Works Oil Filter Relocator - http://www.zerotohundred.com/newfor...s-works-engineering-oil-filter-relocator.html
Works Racing Power Steering Tank - http://www.zerotohundred.com/newforums/engine-and-performance/341350-wts-works-engineering-racing-power-steering-tank.html
Works Throttle Body - http://www.zerotohundred.com/newfor...rks-engineering-power-plus-throttle-body.html
Works Sensor Adapter - http://www.zerotohundred.com/newfor...-wts-works-engineering-sensor-attachment.html
Works Silicone Hose Kits - http://www.zerotohundred.com/newfor...wts-works-engineering-silicone-hose-kits.html
Works Thermal Wrap - http://www.zerotohundred.com/newfor...41355-wts-works-engineering-thermal-wrap.html
Chassis & Handling
APM Performax Suspension Products - http://www.zerotohundred.com/newfor...6-wts-apm-performax-products.html#post3053352
Bendix Metal King Brake Pads - http://www.zerotohundred.com/newfor...ts-bendix-metal-king-titanium-brake-pads.html
Brembo Standard Disc Rotor - http://www.zerotohundred.com/newforums/chassis-and-wheels/341309-wts-brembo-standard-disc-rotor.html
EBC Brake Pads - http://www.zerotohundred.com/newforums/chassis-and-wheels/362688-wts-ebc-brake-pads-made-in-uk.html
Eibach Pro-Kits Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/242432-wts-eibach-products.html
GAB Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/352610-wts-gab-suspension-products.html
Pro RS Steel Brake Hose - http://www.zerotohundred.com/newfor...42876-wts-prors-steel-braided-brake-hose.html
Tanabe Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/359603-wts-tanabe-suspension-products.html
TEIN S-Tech Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/311108-wts-tein-s-tech-lowered-spring.html
TEIN Basic Damper - http://www.zerotohundred.com/newforums/chassis-and-wheels/289072-wts-tein-basic-damper-offer.html
TEIN Super Street - http://www.zerotohundred.com/newforums/chassis-and-wheels/289071-wts-tein-super-street-offer.html
Ultra Racing Bars - http://www.zerotohundred.com/newfor...-wts-genuine-ultra-racing-stabilizer-bar.html
Exterior & Body
Bosch Aerotwin Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/228047-wts-bosch-aero-twin-wiperblades.html
Dyno Silicone Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/303917-wts-dyno-silicone-wiperblades.html
Goodyears Graphite Wiperblades - http://www.zerotohundred.com/newfor...ts-goodyears-silentarmor-graphite-wipers.html
Philips Light Bulb - http://www.zerotohundred.com/newforums/exterior-and-body/229529-wts-philips-lighting-products.html
Tanabe Number Plate Holder - http://www.zerotohundred.com/newforums/exterior-and-body/238776-wts-tanabe-number-plate-holder.html
Interior & Cockpit
Works Gear Knob - http://www.zerotohundred.com/newfor...6-wts-works-engineering-teflon-gear-knob.html
