[wts]Norma Torro hose Clamp
brother
((( God Level 30,000 RPM )))
1.Improved asymmetric housing = even distribution of forces and safe assembly
2.Screw support = Ease of assembly due to the safe guidance of the emerging band end
3.Material and clamping range stamped on the band = prevents mistakes
4.Asymmetric extension = prevents the housing from tilting over when the clamp is tightened
5.Short housing saddle = even contact pressure = improved efficiency
6.Smooth or stamped inside of band = optimal hose protection
The NORMACLAMP® TORRO® multi-range hose clips are – depending on the bandwidth – ideal for use in many different applications with a high mechanical load. With its tensile strength, the high fracture torque and the even tension force distribution plus the constantly improved design it still sets standards for modern hose clips. A TORRO® clip can be recognised immediately and unmistakeably by its typical technical feature: The patented asymmetric construction.
Size available
8-12
10-16
12-20
16-25
30-45
40-60
50-70
60-80
70-90
Price:RM3 to RM7
Contact Person: 0172292882 jack Call or whatsapp
Deal Method: Self Collect,COD,POS or Courier (item willing shipping to any
where.)
Shipping Method:Poslaju,Kangaroo,UPS
Cooz Auto Performance
Lot F25-27 Ground Floor,
CMC Centre Taman Connaught,
Cheras 56000 Kuala Lumpur
(Near UCSI College,McD,Esso petrol station,inside Giant Ground Floor Centre
Court)
Operation hour: 12pm to 9pm Monday to Saturday.
Coo Two Auto Performance(co2 auto)
FK20 first floor,
Axis Atrium shopping mall,
Jalan Cempaka,
68000 Ampang.Selangor D.E
(near tesco ampang just beside MRR2)
(Operation Hour 12pm-9pm)
**you may visit this website for more information thanks
http://www.normagroup.com/kunden/norma/ttw.nsf/id/EN_NORMACLAMP_TORRO_Details
PROMOTION ITEM :party:
  • Arospeed engine damper for Honda Integra DC5
  • Arospeed engine damper Proton Campro
  • Arospeed engine damper for Wira 1.5 1.3
  • Arospeed engine damper for Honda civic EK,EG
  • Arospeed engine damper for proton 1.6 1.8
  • Password bumper diffuser
  • Year End Sale Cooz Auto Performance
  • Arospeed Pulley Set For Kenari,Kelisa,and Myvi 1.0
  • Arospeed Pulley Set For 4G91,92,93
WORKS ENGINEERING PRODUCT
  • SIMOTA Twister Air Intake Kit
Innovate Performance Product(HOT ITEM) Turbosmart Performance Product Engine and performance:driver:
  • http://www.zerotohundred.com/newforums/engine-and-performance/412460-aerospeed-boost-controller.html#post1064014645
[URL="http://www.zerotohundred.com/newforums/engine-and-performance/423786-turbosmart-manual-boost-controller.html"]
  • Turbosmart manual boost controller
  • High Performance oil pump gear for 4G93
http://www.zerotohundred.com/newfor...044-rbp-clutch-for-campro.html#post1064115447
[*]http://www.zerotohundred.com/newforums/engine-and-performance/412451-kelford-camshaft.html#post1064014611
[/LIST]
  • King Race Engine Bearing
[/URL]
  • Exhaust Manifold For GSR and EVO123
  • ARP Head Stud Kits For Mitsubishi EVO 1-9
  • Piper Racing Cam Shaft
  • Banana Turbo Manifold
  • Power Timing Belt
  • JASMA Throttle Body 70MM For EVO1,2,3
http://www.zerotohundred.com/newfor...-wts-jasma-turbo-td05-20g.html#post1064126222
  • JASMA TURBO TD05 18G
  • Power Timing belt
  • Turbosmart Ultragate wastegate 38mm
  • http://www.zerotohundred.com/newforums/engine-and-performance/286704-coozauto-magpower-ii-oil-filter.html
  • Arospeed crank pulley for Kia forte 1.6
  • Arospeed crank pulley for Mitsubishi evo456
  • Works Cam Pulley
  • Hardrace Rear Trailing Arm Bush Honda Civic EK EG
Blow Off Valve(BOV) :driver:
  • TURBOSMART BOV Supersonic
  • SARD R2D2
  • http://www.zerotohundred.com/newforums/engine-and-performance/221383-wts-blitz-b-o-v.
Cooling System:driver:
  • http://www.zerotohundred.com/newforums/engine-and-performance/412447-aerospeed-bubble-tank.html#post1064014600
  • [URL="http://www.zerotohundred.com/newforums/engine-and-performance/412598-aluminium-performance-radiator-greddy-kancil-l2.html#post1064016542"]Aluminium Performance Radiator Greddy Kancil L2
[/URL]
  • Apexi Style Intercooler
  • Aluminium Radiator
http://www.zerotohundred.com/newfor...for-subaru-impreza-ver789.html#post1064118436 Air Filter/Intake:driver:
  • APEXI Mitsubishi EVO 1-9 Air Filter Kit
  • Volkswagan Golf GTI Air Suction Kit
  • REDLINE Drop In Air Filter
  • K&N open pod air filter
  • http://www.zerotohundred.com/newforums/engine-and-performance/259082-wts-toyota-caldina-air-ram-pipe.html
Transmission system:driver:
  • http://www.zerotohundred.com/newforums/engine-and-performance/347670-wts-works-engineering-pro-clutch.html
Fuel Line system:driver:
  • Genuine SARD Regulator
  • SARD Fuel Pump 2.8L
Exterior And Body:driver:
  • Spoon Style Carbon Look Side Mirror For Honda
Chassis and Wheels:driver:
  • REDLINE Rear Lower Arm For Honda EG SR
  • http://www.zerotohundred.com/newforums/chassis-and-wheels/412466-hardrace-rear-lower-arm-for-honda-ek-eg.html#post1064014659
http://www.zerotohundred.com/newfor...-lower-arm-set-for-proton.html#post1064188373 Silicon hose:driver:
  • Samco radiator hose for Perdana v6 twin turbo
  • Samco silicone radiator hose kit honda civic EK B16A
Electronic & Gauge:driver:
  • Haltech Platinium Sprint 500
  • Innovate exhaust clamp
  • Innovate lm2 obd2 cable
  • ECUTECH Power Box for Volkswagen MK6 MK5
http://www.zerotohundred.com/newfor...19049-pivot-speed-meter-v.html#post1064115482
  • Haltech Pro-Plug In Series
  • Redline Electronic boost controller golf gti mk5 mk6
  • RPM Meter with EL light black face
  • Greddy Profec B-Spec 2 Boost Controller
  • Greddy V-emanage
  • Greddy E-Manage
Interior and Cockpit:driver:
Accessories:driver:
  • Stearing Quick Release NRG
  • http://www.zerotohundred.com/newforums/engine-and-performance/412454-boom-sticker-side-mirror-for-honda-ek-eg.html#post1064014618
  • http://www.zerotohundred.com/newforums/engine-and-performance/412449-nrg-steering-deep-dish.html#post1064014607
http://www.zerotohundred.com/newforums/exterior-and-body/296313-sparco-style-bonnet-spring-hook.html
  • http://www.zerotohundred.com/newforums/interior-and-cockpit/200615-wts-wira-saga-gear-short-shift.html
  • http://www.zerotohundred.com/newforums/automotive-wear-and-ware/380623-wts-turbo-key-chain.html
http://www.zerotohundred.com/newfor...-wts-mugen-rear-spoiler-emblem-aluminium.html
  • Honda CRZ Red emblem logo
  • http://www.zerotohundred.com/newforums/all-other-stuff/391971-wts-sport-emblem.html#post1063762452
Engine Oil:driver:
  • Arospeed Oil Sum Nut
Used Part:driver:
  • http://www.zerotohundred.com/newforums/engine-and-performance/412444-greedy-type-r-bov.html#post1064014586
  • Mitsubishi evo side miror flip for wira
Location: COOZ AUTO PERFORMANCE LOT F25-27 GROUND FLOOR, CMC CENTRE JALAN CERDAS, TAMAN CONNAUGHT,56000 CHERAS KUALA LUMPUR. (Near UCSI College, Inside Giant Ground Floor) contact person: 017-2292882 Jack or Email [email protected] Click Here" or Log on coozauto.blogspot.com *our show Room Open at 12pm to 9pm Monday to Saturday.welcome to visit us. *the page still in construction sorry for unconvinced
