http://hi-rev.com.my/templates/rt_dimensions/images/logo.png
FULLY SYNTHETIC - SM 9030
http://img38.imagefra.me/img/img38/2/9/15/s2000eve/f_lx8yfy1ejm_6e868fa.jpg
Product Description
HI-REV 9030 SAE 10W-30 is a high performance, highly shear-stable, fully synthetic, multigrade passenger car motor oil formulated from selected synthetic base fluids – PAO & XHVI plus. It is optimized to provide outstanding thermal stability, improved viscosity-temperature characteristics and exceptional low-temperature fluidity for the ultimate in protection and performance in all passenger car and light truck gasoline engines operating under the most severe condition.
Performance Standards
SAE 10W-30
API SM/CF
Customer Benefits
• Excellent oxidation resistance and advanced additive package ensure prolonged engine service life and effective oil performance even under sub-zero and extreme high temperature service conditions.
• Lower maintenance cost with longer oil drain intervals and excellent long term engine wear protection due to the rapid formation of a durable anti-wear film
• Low viscosity, rapid oil flow and low friction effectively contribute towards reducing fuel consumption
• Does not affect catalytic converters efficiency
Typical Applications
Recommended for the ultimate protection of all naturally aspirated, turbocharged, fuel injected and multivalve passenger car engine fuelled by either gasoline or diesel.
Compatible with both conventional mineral-based and synthetic motor oil.
Typical Properties
SAE Grade 10W-30
Viscosity, cSt @ 40 Deg C 75.2
@ 100 Deg C 11.6
Viscosity Index 148
Zinc, mass% 0.08
TBN, mgKOH/g 7.3
SEMI SYNTHETIC - SM 7040
http://img39.imagefra.me/img/img39/2/9/15/s2000eve/f_lx8ygcomem_562830b.jpg
Product Description
High performance, semi-synthetic, multigrade crankcase oil that fortified with the most advance additive formulation to provide excellent performance and protection in passenger car and other light truck of high-performance, four-cycle gasoline engines.
SAE 10W-40
API SM
ILSAC GF-4
Customer Benefits
1.Excellent low temperature properties to help speed cold starts
2.Exceptional deposit control
3.Superior wear protection that promotes engine durability
4.Friction modifier and anti-wear additive improve power and lower fuel consumption by minimizing wear in even the most sophisticated valve train mechanisms, including those with variable valve timing
5.Excellent rust and corrosion protection of critical engine parts
Recommended for all passenger cars and light truck four-cycle gasoline engines, both naturally aspirated and turbo-charge, including those featuring the most recent valve train and emissions control technologies.
MINERAL BASE - F 5000
http://img39.imagefra.me/img/img39/2/9/15/s2000eve/f_nv084r79h0sm_6d58756.jpg
Product Description
High-performance, shear-stable, multigrade crankcase oil, which provides excellent performance and protection in passenger car and other light truck engines where API SG or CF performance lubricants are required.
API SG/CF
SAE 20W-50
ACEA A2/B2
Customer Benefits
1. Effective detergent-dispersant additive system maintains performance by controlling sludge and deposits formation.
2. The metallo-organic anti-wear additive system, good thermal stability and oxidation resistance offer protection against wear, resistance to oil degradation and protection against resultant engine damage under severe high-temperature operations conditions.
3. High Viscosity Index
Recommended for all passenger cars and light truck four-cycle gasoline engines, both naturally aspirated and turbo-charged.
PRICE LIST
FULLY SYNTHETIC - SM 9030 - 10W-30 - RM 170.00
SEMI SYNTHETIC - SM 7040 - 10W-40 - RM 95.00
MINERAL BASE - F 5000 - 20W-50 - RM 60.00
PRICE INCLUDING LUBRICANT CHANGE SERVICE[/color]
PLEASE CALL OR SMS FOR MORE INFOS!
http://img38.imagefra.me/img/img38/2/9/4/s2000eve/f_1dmknvkwhu8m_6ce432d.jpg
Product Description
SAE 10W-30
API SM/CF
Customer Benefits
Typical Properties
SAE Grade 10W-30
@ 100 Deg C 11.6
Viscosity Index 148
Zinc, mass% 0.08
TBN, mgKOH/g 7.3
Product Description
SAE 10W-40
API SM
ILSAC GF-4
Customer Benefits
Product Description
API SG/CF
SAE 20W-50
ACEA A2/B2
Customer Benefits
PRICE LIST
