WTS headlight restore
ImFatButImCute
https://www.zerotohundred.com/forums/attachments/449848.vB
We are specialist in Plastic headlight restoration and headlight REPAIR.
The provided services.
1) Reborn your headlight to new and shine
2) Restore the cracked plastic headlight to 90% new condition
3) 3 years warranty
Remark:
- using a special technique and chemical for the restoration but NOT only Polish as common in the market.
- New in market and we are the only 1 that can RESTORE CRACKED plastic headlight
- Minimum 3 days for the processing period
COD- we only COD headlight (we dont provide removal and installation)
COD Area : seri kembangan, OUG, kechai lama.
Price: Rm200 - Rm250 (per unit)
For more information,
Pls call 017-6711233 Eddie Foo
Please refer to the following for BEFORE & AFTER pictures.
If interested, please feel free to PM me. Thanks!
After
Espri detomaso headlight just restore 2 days ago.
Before:
1) The headlight almost 70% CRACKED
2) The headlight turn back to yellow 20% (3 month ago polish by painting shop Rm 120)
After:
1) Restore 90% Cracked
2) New and shine 100% (3 years warranty)
Warranty 3 years is only for yellowish ( Guarantee can last more then 3 years)
Crack I can't warranty because crack come in two ways (inside) and surface ( outside) ,
but after restore (outside) mostly the crack will not return n increase.
If u request us fix the inside crack, we will do it in more expensive price due to more complicate works.
If the inside crack is not that serious, we will recommend you to fix the surface crack only because 90% cracked is from surface.
Remark
Why we can warranty 3 years
Why most luxury car headlight can last for 10 years ?
(We are using almost the same chemical as luxury car.)
Why need 3 days in progress ?
1) we need to remove yellowish and cracked surface
2) apply ( A chemical ) for restore cracked need 6 hours for dry up
3) apply ( B chemical ) for shinning and uv protection 4 hours for dry up
Before
After
