(WTS) Go Pro HD HERO 960
Car Culture
rattan
1,500 RPM
GoPro HD HERO 960 Wearable HD Camera
Complete set in box. Used only few times.
Comes with headband holder, helmet grip, waterproof casing, box and acrylic camera packaging. Like new.
No sd card included.
Pm me to deal.
First come first serve.
SOLD !
Specification :
Lens Type Fixed Focus (2ft/.6m), glass
Aperture f/2.8 (high performance in low-light situations)
Angle of View 170 Deg.F ultra wide angle in WVGA, 720p, or 960p mode
HD Video Resolution Modes 960p: 1280x960 pixels (4:3), 30 fps, 12 Mbit/s data rate
720p: 1280x720 pixels (16:9), 30 fps, 8 Mbit/s data rate
WVGA: 848x480 pixels (16:9), 60 fps, 8 Mbit/s data rate
Sensor Type 1/2.5" HD CMOS, 2.2micrometre-sized pixels
Light Sensitivity Super low-light sensitivity (> 1.4 V/lux-sec)
Video Format H.264 compression, saved as Windows- & Mac-compatible MPEG4 (.mp4) file
Exposure Control Auto with user selectable center weighted average and spot metering settings
White Balance Auto
Microphone Built-in, mono with AGC (automatic gain control)
Audio Format 48 kHz, AAC audio compression
Resolution 5 megapixel
Capture Modes Single shot, photo every 2, 5, 10, 30 or 60 secs.; 3 photo burst; self-timer
Memory SD card, up to 32GB capacity (SDHC)
Average recording times 960p (30 fps): 5h 26m
720p (30 fps): 8h 09m
WVGA (60 fps): 8h 09m (using 32GB SD card)
PC Connection USB 2.0 (data connection and battery charging)
HDTV Out HD NTSC & PAL (component cable incl.)
Audio Out Combo 2.5mm jack with stereo audio and composite video out
PC Compatibility Windows Vista or Windows 7; Mac OS X 10.4.11 and later
Battery Type Rechargeable 1100 mAh lithium-ion
Battery Life Approx. 2.5 hrs
Charging Via USB to computer or optional power adapter
Charge Time 80% capacity after 1 hour with optional power adapter; or 2 hours with a computer's USB port
Housing Depth Rating Up to 180 feet / 60 meters
Housing Construction Polycarbonate and stainless steel
Housing Hardware Stainless steel
Dimensions (H x W x D) 1.6" x 2.4" x 1.2" (42mm x 60mm x 30mm)
Weight 3.3oz (94g) incl. battery, 5.9oz (167g) incl. housing
