By increasing condenser capacity and through improvements made to circuitry, not only gas voltage stability been enhanced, but our newly improved voltage meter means improved voltage supple which in turn means no loss in battery life or performance and the possibility of reaching 100% performance.
Voltage Stabilizer
Mega Raizin by increasing the capacity of the condenser three-fold (compared to Blue RAIZIN), and decreasing both circuitry noise and high frequency impedance the results have been a more stable supply of voltage to all electronic devices, better gas mileage, and improved torque and audio quality.
Benefits:
- Improved audio quality
- Increased torque and response and power
- Stabilized idling and improved engine kick over
- Increased headlight brightness
- Improved fuel economy
- Improved battery life
Grounding kits:
- Faster engine start-up
- More stable idling
- Smoother and faster throttle response
- Increase low & middle engine torque
- Better millage
- Cleaner exhaust gas
- Brighter headlight output
- Improve car audio sound quality
Pivot Voltage Stabilizer Mega Raizin with Earth Wire (VS-ME)
Rm480.00
Voltage Stabilizer
Benefits:
Pivot Voltage Stabilizer Mega Raizin (VS-M)
Rm380.00
Voltage stabilizer in combination with supplementary earth bring you electrical efficiency
Raizin brings you not only ideal electrical efficiency and voltage supply stabilization, but with our original circuitry design and our special noise reduction condenser you can enjoy diminished noise and lessened
high-frequency impedance.
Benefits:
Grounding kits:
- Better millage
Pivot Voltage Stabilizer With Earth Cable (VS-E)
Rm250.00
Benefits
Pivot Voltage Stabilizer (VS-1)
Rm150.00
Type S can be easily wired by a one-touch connection to the interior fuse box (ignition). It is also possible to switch the power between +B (normal power) and IG+ to match your car model setup. Moreover, peace of mind comes in knowing that the unit is equipped with a delay circuit to avoid trouble caused by power bursts during battery recharging when using IG+ ON.
Newly Designed Honeycomb Condenser
Our exclusive newly designed condenser, which includes honeycomb shapes in various places, has superior frequency response characteristics that help to bring about incredible noise reduction and results in more stabilized voltage, as well as, achieves both optimum high frequency wave responsivity and improvement in electrical capacitance.
Interior Installation.
Pivot Raizin Spark Type-S VS-S
Rm270.00
Designed for car audio, not only greatly cuts noise, but the stabilized voltage supply to each unit brings you higher quality audio sound.
- Brings you vivid trebles and mediants, as well as, more resonant bass sounds.
- Outstanding results for both standard audio and full component audio.
Pivot Raizin Sound CA-VS
Rm220.00
Engine performance is greatly improved due to a more stable ignition which is brought about by the double effect of a strengthened earthing system and the noise filter circuitry that quickly suppresses noise when the ignition coil fires.
Due to differences in electrical design, the increase in performance level will differ by car model.
Pivot Spark Earth (SES)
Rm170.00
The additional earth wire on our Composite Earth Cable has a conductor circumference 2.5 times the normal wire. This improves the firing speed by reducing voltage loss and increasing conductivity of high frequency waves released by the ignition coil. Moreover, by facilitating ionization during combustion, it improves gas mileage and engine torque. (Patent pending)
Pivot Ignition Earth (IE)
Rm190.00
By simply inserting into the cigarette lighter socket, you can not only improve the performance of electronic devices by supplying a stable source of voltage, but it is also possible to check the current status visa the voltage meter.
Voltage Stability brings Improved Performance
- Engine Torque
- Audio Quality
- Mileage
- Light illuminance
Checking Voltage gives Protection from Performance Loss
- Lower Voltage means Lower Quality Sound / Unstable Operation for all Electronic Devices
- Low Battery Charge
- Battery Life
Pivot V capa
Rm300.00
*Price might change without notification, kindly contact me to confirm the price. TQ
*Please Inquiry / Order by E-mail
Website: www.xd-auto.com
Contact No.: KentGoh - Digi 6 - 337 3368
E-Mail: [email protected]
Shop Location: Kepong Jaya Jusco
Installation & Tuning: Kepong Jaya Jusco
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Lunch Time: 1.00pm - 2.00pm
Delivery Service: 11.00am - 6.00pm (Monday - Saturday)
Our shop:
Win Hong Auto Trading Sdn Bhd
No.153, Jalan Besar Kepong, 52100 K.L
Maps: http://wikimapia.org/#lat=3.2139519&lon=101.6382739&z=18&l=0&m=m&search=win hong auto
Dear All Members and Forumers,
I would appreciate if you guys kindly DO NOT PM/Call to me especially on XD-Autoparts related Products, Quotation, Technical Issues and etc.
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368. This is to ensure better tracking and a more efficient follow up.
Thank you for understanding, cheers.
Regards,
KentGoh
Engine Performance & Compartment
ASR Silicone Hose - http://www.zerotohundred.com/newfor...s-asr-silicone-hose-products.html#post4121197
Auto Service & Replacement Parts - http://www.zerotohundred.com/newfor...cement-and-performance-parts.html#post3858120
Bardahl Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341331-wts-bardahl-fully-5w30-and-5w40-rm85.html
Bosch Fusion Spark Plugs - http://www.zerotohundred.com/newfor...ance/237425-wts-bosch-fusion-spark-plugs.html
Bosch Type-R Oil Filter - http://www.zerotohundred.com/newfor...mance/244853-wts-bosch-type-r-oil-filter.html
Chemlube Lubricants - http://www.zerotohundred.com/newfor...chemlube-100-syncthetic-with-ester-based.html
Cold Air Intake Hose - http://www.zerotohundred.com/newforums/engine-and-performance/234747-wts-cold-air-intake-hose.html
Exedy Clutch - http://www.zerotohundred.com/newfor...ce/341326-wts-exedy-clutch-and-fly-wheel.html
Forged Racing Radiator - http://www.zerotohundred.com/newforums/engine-and-performance/362689-wts-forged-racing-radiator.html
Pivot Products - http://www.zerotohundred.com/newfor...223310-wts-genuine-pivot-raizin-products.html
Haydens ATF Cooler - http://www.zerotohundred.com/newfor...-hayden-transaver-all-weather-protection.html
Denso Iridium Spark Plugs - http://www.zerotohundred.com/newfor...nce/303916-wts-denso-iridium-spark-plugs.html
K&N High Flow Filter - http://www.zerotohundred.com/newfor...-n-high-flow-drop-in-and-open-pod-filter.html
Motul Lubricants - http://www.zerotohundred.com/newfor...ance/223342-wts-motul-lubricant-products.html
Pennzoil Lubricants - http://www.zerotohundred.com/newfor...ance/341332-wts-pennzoil-platinum-series.html
Q8 Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341333-wts-q8-lubricants-products.html
Redline LCP - http://www.zerotohundred.com/newforums/engine-and-performance/322721-wts-redline-lightening-crank-pulley.html
Hot InaZma Products - http://www.zerotohundred.com/newfor...-products-hot-inazma-hot-earth-hg-pocket.html
Torco Lubricants - http://www.zerotohundred.com/newfor...41337-wts-torco-sr-1-and-sr-5-lubricants.html
Works Air Intake System - http://www.zerotohundred.com/newfor...-wts-works-engineering-air-intake-system.html
Works Cam & Crank Pulley - http://www.zerotohundred.com/newfor...s-works-engineering-cam-and-crank-pulley.html
Works Drop In Filter - http://www.zerotohundred.com/newfor...724-wts-works-engineering-drop-in-filter.html
Works Fuel System - http://www.zerotohundred.com/newfor...341343-wts-works-engineering-fuel-system.html
Works Magnetic Oil Sump Nut - http://www.zerotohundred.com/newfor...-works-engineering-magnetic-oil-sump-nut.html
Works Oil Cooler - http://www.zerotohundred.com/newfor...ering-oil-cooler-engine-and-transmission.html
Works Oil Filter Relocator - http://www.zerotohundred.com/newfor...s-works-engineering-oil-filter-relocator.html
Works Racing Power Steering Tank - http://www.zerotohundred.com/newforums/engine-and-performance/341350-wts-works-engineering-racing-power-steering-tank.html
Works Throttle Body - http://www.zerotohundred.com/newfor...rks-engineering-power-plus-throttle-body.html
Works Sensor Adapter - http://www.zerotohundred.com/newfor...-wts-works-engineering-sensor-attachment.html
Works Silicone Hose Kits - http://www.zerotohundred.com/newfor...wts-works-engineering-silicone-hose-kits.html
Works Thermal Wrap - http://www.zerotohundred.com/newfor...41355-wts-works-engineering-thermal-wrap.html
Chassis & Handling
APM Performax Suspension Products - http://www.zerotohundred.com/newfor...6-wts-apm-performax-products.html#post3053352
Bendix Metal King Brake Pads - http://www.zerotohundred.com/newfor...ts-bendix-metal-king-titanium-brake-pads.html
Brembo Standard Disc Rotor - http://www.zerotohundred.com/newforums/chassis-and-wheels/341309-wts-brembo-standard-disc-rotor.html
EBC Brake Pads - http://www.zerotohundred.com/newforums/chassis-and-wheels/362688-wts-ebc-brake-pads-made-in-uk.html
Eibach Pro-Kits Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/242432-wts-eibach-products.html
GAB Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/352610-wts-gab-suspension-products.html
Pro RS Steel Brake Hose - http://www.zerotohundred.com/newfor...42876-wts-prors-steel-braided-brake-hose.html
Tanabe Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/359603-wts-tanabe-suspension-products.html
TEIN S-Tech Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/311108-wts-tein-s-tech-lowered-spring.html
TEIN Basic Damper - http://www.zerotohundred.com/newforums/chassis-and-wheels/289072-wts-tein-basic-damper-offer.html
TEIN Super Street - http://www.zerotohundred.com/newforums/chassis-and-wheels/289071-wts-tein-super-street-offer.html
Ultra Racing Bars - http://www.zerotohundred.com/newfor...-wts-genuine-ultra-racing-stabilizer-bar.html
Exterior & Body
Bosch Aerotwin Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/228047-wts-bosch-aero-twin-wiperblades.html
Dyno Silicone Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/303917-wts-dyno-silicone-wiperblades.html
Goodyears Graphite Wiperblades - http://www.zerotohundred.com/newfor...ts-goodyears-silentarmor-graphite-wipers.html
Philips Light Bulb - http://www.zerotohundred.com/newforums/exterior-and-body/229529-wts-philips-lighting-products.html
Tanabe Number Plate Holder - http://www.zerotohundred.com/newforums/exterior-and-body/238776-wts-tanabe-number-plate-holder.html
Interior & Cockpit
Works Gear Knob - http://www.zerotohundred.com/newfor...6-wts-works-engineering-teflon-gear-knob.html
