WTS: Genesis Profile Sub
ICE -In Car Entertainment
ivankwk
Hi all,
I have a used unit of Genesis Profile Sub for sale. Used for two years. Only the amp without the sub level control. COD in Puchong or Subang
attachment.php
Below are the specifications
Profile Sub
Designed to drive modern subwoofers at high levels with perfect control, Profile Sub delivers 500 watts of pure power for bass you can feel as well as hear. Optional Remote Level control for easy level adjustment. Separate Subsonic and Low pass filters for total control Parametric EQ allows tuning of sub system to suit all music styles while Class G keeps everything cool.
Specification:
1 x 350W at 4 ohms / 1 x 500W at 2 ohms
Features
Power Levels [2 Ohms] -1 x 550W
Power Levels [4 Ohms] -1 x 350W
Bridge -N/A
THD -
Signal to Noise Ratio - 100dB 'A' Wtd
Input Sensitivity [Volts RMS] - 0.3 ~ 4 Volts
Current Draw @ 4 Ohms - 30 Amps
Fuse Rating - 2 x 30 Amp
Crossovers HP [All Continuous] - CH 1 - 20 - 200 Hz
Crossovers LP [/- Module] - CH 1 - 50 - 200 Hz
Parametric Equalizer - Yes
Dimensions H x W x D [mm]* - 38 x 300 217
Weight [Kg] - 2.0
