[WTS] Eclipse SC8365 3-Way Component Set
ICE -In Car Entertainment
ACG-KAiZEN
1,500 RPM
Item(s): Eclipse SC8365 3-Way Component Set
Package Includes: 1 pair each of 3/4" Tweeter & 1-1/2" Midrange + Mounting Bracket, 6.5" Midbass + Grille & 3-Way Crossover
Price: :listen:SOLD!!! SOLD!!! SOLD!!!:listen:
Dealing method: Prefer COD (KL, Damansara, Kelana Jaya, Subang Jaya, Sunway, Bandar Utama & PJ Area)
Contact method/details: 012-21 363 07 / 016-351 3337
Item(s) conditions: ITEM IS IN PERFECT AND MINT.
Picture: As Attached
The Eclipse SC8365 is a 3-way component system that will enhance the sound of your audio system many times over. It features two woofers, two mid-woofers, two tweeters, and two crossover networks. That means that there will be three speakers on each side of the vehicle. With the audio signal traveling through the crossover, each speaker will only produce a particular set of frequencies that is best for that particular driver. That means that the mid-woofer will produce only the frequencies that the mid-woofer is designed for. This is the same concept for the tweeter and the woofer. Not only does this protect the speakers from receiving frequencies that the woofer is not designed for, but also the sound is clearer and cleaner. If you don’t necessarily have the space in your car doors or dash to install 2 extra speakers, the Eclipse SC8365 comes with a mounting bracket that attaches the mid-woofer and the tweeter together for a convenient way to mount two speakers in a single location. With the Eclipse logo branded on these components, you can be sure that the speakers are of the highest audiophile quality that Eclipse is known for. Advanced crossover networks allow the separation of frequencies to be direct and accurate. They are available in both 5-1/4” systems and 6-1/2” systems. If you are looking to add new speakers in your current car or even getting the components ready for your next vehicle, be sure to check out these incredible 3-way component speaker systems from Eclipse!
Up for sale is one (1) set used Eclipse SC8365 3-Way Component Set. Very powerful, clean & responsive components. Perfect choice for mid level SQ ICE'ers. You'll deffinitely be satisfied with its performance. I had been through several sets of comps that either didn't sound great or didn't handle to high power and high volume that I use my equipment at. I finally settled on a couple pairs of these bad boys, after some recommendations from friends. Awesome, great sounding mids and highs, durable, and cosmetically pleasing. The spec for the Eclipse are as attached below:
Features:
- 6-1/2" 3-way Component System
- Power Handling:
* Peak: 600 watts per set / 300 watts each side
* RMS: 200 watts per set / 100 watts each side
- Solid Aluminum Cone
- Acoustic Thruster Technology
- Durable Butyl Rubber Surround
- Flat Spider for faster, longer excursion linear motion
- Frequency Response: 30 - 25,000 Hz
- Sensitivity:
- 4 ohm Impedance
