[WTS] [EA] Kicker CVR 2009 model Clearance
ICE -In Car Entertainment
howiechoo
8,000 RPM
http://userland.fotopic.net/logos/358416.gif
Kicker CVR 12 2009 Clearance
As title descripted, i was clearing stock for this subwoofer...grab it while stock last
http://www.zerotohundred.com/newforums/attachments/ice-in-car-entertainment/332483d1286864178-wts-ea-kicker-cvr-2009-model-clearance-images.jpg
RMxxx last pc available
Legendary CompVR sound
SoloKon for strength and accuracy
T cut top plate for magnetic field strength
Polyimide (Kapton) coil former with Nomex reinforcement for high thermal capability
Spiralead tinsel leads enable high excursion
Ribbed Santoprene surround
Size (IN.,CM) 12, 30.5
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 800/400
Sensitivity (dB 1w/1m) 86.7
Frequency Response (Hz) 25-500
Mounting Depth (IN.,CM) 6 5/16, 16.1
Mounting Cutout (IN.,CM) 11 1/8, 28.3
Min Rec Sealed Box Volume (CU. FT., Liters) 1, 28.3
Max Rec Sealed Box Volume (CU. FT., Liters) 4.6, 130
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.7
interest pls call: 012-767l360 Howie
Agent wanted too, if you interest with wholesales, contact me as well
Bukit Jalil, Aked Esplanad
