[WTS] Denso Iridium Spark Plug RM140!!!!!!!!!!!!
Opel
Item(s):100% All new Denso Iridium Spark Plug
(IK20,IK22 and IK 16 availble now!, other model available very soon)
Price: 140 where to find such lower price? ...bear in mind 100% GENUINE and NEW...
Dealing method: COD/ Poslaju
Location of seller:JB
Contact method/details:PM/ sms 016-7118469
Picture: Later
Payment: COD/ maybank2u acc no:154026356494
Ignitability That's a Cut Above
With DENSO's very own U-Groove ground electrode for better spark performance
To increase ignitability, the important point is to let the flame kernel caused by the spark to grow to a large size. Normally, this can be accomplishing by widening the spark gap, however this causes spark voltage to increase, which has the opposite effect. IRIDIUM POWER uses DENSO very own U-Groove ground electrode to realize a superb ignitability while maintaining spark voltage at low levels.
Improved Horse Power(1)
Get more power with an optimal combustion cycle.
IRIDIUM POWER has a low required voltage and a high ignitability, resulting in less misfiring and no spark, the outcome being a dramatic improvement in combustion. Engine output is thus increased. The findings of a bench test using a motorcycle engine to show the improved combustion from IRIDIUM POWER is shown on the below. Compared to normal plugs, a 0.5ps (1.4%) improvement is seen in output at 110km/h.
diagram
Improved Acceleration
Increased response and acceleration performance.
IRIDIUM POWER best demonstrates its performance improvement during acceleration.IRIDIUM POWER has a 0.4 mm diameter iridium center electrode and a specially shaped ground electrode. These features combine to achieve higher ignitability and require lower spark voltage than ever before. This enables high-response driving with fewer misfires than under higher required voltage spark conditions, and fewer misfires when ignitability is difficult. As a result, acceleration improves in comparison with normal plugs.
diagram
Improved Horse Power(2)
The 0.4mm center electrode increases output under various driving conditions.
The power produced by the 0.4mm dia. iridium center electrode is IRIDIUM POWER unmatched by other plugs. The graph below compares the resulting power when IRIDIUM POWER is installed compared to other high performance plugs. Using a 0.4mm dia. fine center electrode, there is more power compared to 0.8mm and 2.5mm dia. plugs. This is what makes the difference in acceleration and in your lap time. diagram
Improved Fuel Mileage
Even during idling ignition is assured, with less fuel consumption and less noise.
The good ignitability from the fine electrode (0.4mm) of IRIDIUM POWER draws out much more performance from the engine. Comparing a normal plug (W20FS-U) with an IRIDIUM POWER(IWF22) on a 2 cycle 50cc engine, fuel consumption improved from 41.74km/L -> 43.69km/L, an improvement of about 5%.
Note: Mileage measured using a chassis dynamo; actual driving results under normal conditions may vary.
The Secret behind DENSO's Iridium Patent!
Plug electrodes conventionally have used nickel and platinum. These were not pure metals, but alloys containing other metals. Depending on the composition of the alloy, the matrix material's properties can be maximized. Using the same approach, iridium is alloyed with rhodium. The rhodium layer covers the iridium, improving the properties of the iridium. This iridium/rhodium technology was recognized by the Patent Offices of Japan and the UK, and in January 1999, a patent was granted in each respective country. (Patent Number - Japan: 2877035, UK: 2302367). Because DENSO had this patented technology, DENSO was able to make dia. of the iridium down to 0.4mm.
The most important things for plug performance are ignitability and sparkability. To make the electrode as fine as possible is the goal of spark plug manufacturers worldwide, and DENSO has taken the lead, succeeding the commercializing the 0.4mm dia. center electrode plug.
diagram
The finer the electrode, the more concentrated the electrical potential and the stronger the electrical field strength becomes, leading to a lower required voltage. This results in a steady combustion in a variety of driving conditions, and better starting and acceleration for the engine.
A Pattern from Spark to Ignition.
Electrodes have a quenching (cooling) affect (where the heat of the ignited flame kernel is taken away by the electrode). This cooling affect is greater with larger electrodes, sometimes causing the ignition to stop short of the stage in Figure 4. To improve ignitability, the contact area between the electrode and the flame kernel must be reduced. Improved ignitability is why IRIDIUM POWER electrodes have been made fine as possible.
diagram
Find Your Plug HERE
DENSO IRIDIUM POWER PROMO VIDEO
ANOTHER PROMO VIDEO
FAQ
Q. Do I need to set the gap?
A. Generally, no. The DENSO Iridium Power plug comes pre-set with a protective sleeve over the firing end, to protect the gap from accidental alteration. DENSO Iridium Power’s ultra-efficient firing power compensates for normally recommended gap settings that are smaller than the pre-set value. In the cases of vehicle modifications (nitrous, turbo-chargers, super-chargers, high power ignition systems, etc.), some adjustments may be desired. Or, if you prefer to remain consistent with factory specifications, you may adjust. However, please be careful not to place any stress on the fine center electrode during adjustment. You could accidentally break off the very hard, and therefore brittle, tip.
IMPORTANT
Procedure of Poslaju/Outstation Deal,
1. Buyer Notify the model of Iridium plug he/she intend to buy
2.Buyer Bank in the amount of payment: RM140 for set of 4 plugs + RM8 for postage (POSLAJU - nationwide), at the same time buyer PM/SMS me the details of contact, Name, Address, Contact Number.
3. I will proceed to sent the item via poslaju after payment details has been confirmed.
4. If requested by buyer i will send the buyer the S/N number of the poslaju receipt (for tracking purposes).
5. Buyer receive the item via poslaju and enjoy the power of Denso Iridium
having confidence buying from me? see my tag
ORIGINAL LOWYAT.NET LINK Lowyat.NET -> [WTS] Denso Iridium Power Spark Plug
UPDATE:Fresh Supply of Spark Plugs....but it will be sold off within these 3 days....(mostly has been reserved)
Note: Denso Spark plug catalogue is for reference only...not for sale
[addedon]December 29, 2007, 4:22 pm[/addedon]29/12/2007: Sold 8 Sets to Volvo Club Malaysia Johor Div this morning... Thanks for support!
IK20 and IK22 run out of stock temporary... will bring in more very soon
According to Denso Official Catalog Chart
Mitsubishi 4G93 (non mivec/ turbo/GDi) using IK16
and 4G91 using IK20
New stuffs!! Spark Plug Training Manual from Denso!
Wanna know whats inside? Stay Tuned!
:lol:
[addedon]January 1, 2008, 10:45 pm[/addedon]Uploads of the day:
answer to the heat range comparison
Comparison to other Spark Plug Manufacturer
Spark Plug Gapping????
Sorry for the image quality, scanner spoiled just when i need it the most....
