[WTS] BLITZ Throttle Controller
350_GT
Blitz Throttle Controller
http://www.blitzperformancesales.com/products/throcon/images/throcon_ttl.jpg
http://img123.imageshack.us/img123/121/blitzthottleunitgraphde7.jpg
1. Vehicle Specific Designed, Plug and Play easy installation. (Some application require wiring)
2. 16 kinds of Vehicle Specific Harness applicable more than 80 Japanese makes & models to be match.
3. Pre-Programmed modes "ECO" / "SP1" / "SP2" / "SP3" will provides to meets your driving feeling. Selected mode clearly indicates on a display screen. The mode can be select at your desire manner even while in driving by just simply pressing buttons locate a side of the display.
4. Equipped with Safety Function which the unit automatically returns to "OFF" mode every each time engine has shut off and manually needed to turn "ON" after engine has started. The vehicle runs at factory stock basis while Throttle Controller is in "OFF" mode. This makes worry free from driving your car who is not familiar to Throttle Controller.
5. "OFF" mode also can be choosing at your desire manner by just pressing the button.
WHAT DOES THROTTLE CONTROLLER WILL DO?
Recent trend of automobile equipped with Electric Controlled Throttle Valve replaced from Mechanical Throttle Valve (Cable type). The electrically controlled throttle valve is one of updated technology in automobile industry and the technology brings a precise throttle valve control enable to adjust acceleration characteristic for much more fuel conservative yet causing gap in acceleration response in the other end.
BLITZ Throttle Controller eliminates acceleration gap as much as possible by converting electric signal by the use of pre-programmed characters (modes). Throttle Controller is an item which improves acceleration response.
The unit includes Vehicle Specific Wire Harness, which makes Plug & Play easy installation (some vehicle may require 12v power wiring). Most application simply plugs in Vehicle Specific Wire Harness in between a accelerator-pedal position sensor and a factory stock wiring which is most of time located close to accelerator pedal. Display Units and Control Box are separated individually made display unit light and compact enough to place easy on dashboard area.
BLITZ Throttle Controller is a most reliable unit among in the market as well as an easiest solution to improve accelerator response.
RM1600 with harness
contact : 017 772 8786
loc : Subang,Selangor.
