[WTS] ASR Silicone Hose Products
Kent_Goh
http://1.bp.blogspot.com/_EXMuk9dtlwk/TAh6IOA2a1I/AAAAAAAAFVQ/dczEaXAR6bE/s400/IMG_3991-1.jpg
ASR Silicone vacuum hose are manufactured from high grade silicon polymer, this gives a minimum/ maximum operating temperature range of -20ºC to +120ºC. For operating parameters outside of these limits please inquire.
Specifications:
- Resists Heat -20°C-120°C
ASR Silicone Vacuum Hose:
Vacuum Hose 4mm - Rm25.00/Meter
Vacuum Hose 6mm - Rm35.00/Meter
ASR Silicone Straight reducer hose are manufactured from high grade silicon polymer, and reinforced with high strength polyester fabric. This gives a minimum/ maximum operating temperature range of -40ºC to 180ºC. For operating parameters outside of these limits please inquire.
Specifications:
- Resists Heat -40°C-180°C
- 3 Layer
- Wall thick 3.5mm
- Length 76mm
ASR Silicone Reducer Hose:
51mm > 38mm - Rm45.00
51mm > 45mm - Rm45.00
54mm > 51mm - Rm45.00
57mm > 51mm - Rm45.00
60mm > 50mm - Rm45.00
63mm > 45mm - Rm45.00
63mm > 51mm - Rm45.00
63mm > 57mm - Rm50.00
70mm > 50mm - Rm55.00
70mm > 57mm - Rm55.00
70mm > 60mm - Rm55.00
70mm > 63mm - Rm55.00
76mm > 45mm - Rm55.00
76mm > 51mm - Rm55.00
76mm > 57mm - Rm55.00
76mm > 63mm - Rm60.00
76mm > 67mm - Rm60.00
76mm > 70mm - Rm60.00
80mm > 70mm - Rm65.00
89mm > 76mm - Rm70.00
90mm > 80mm - Rm70.00
102mm > 76mm - Rm75.00
102mm > 89mm - Rm80.00
ASR Silicone Coupling hose are manufactured from high grade silicon polymer, and reinforced with high strength polyester fabric. This gives a minimum/ maximum operating temperature range of -40ºC to 180ºC. For operating parameters outside of these limits please enquire.
Specifications:
- 3 Layer
- Wall thick 3.5mm
- Length 76mm
*Red highlight - 5mm wall thickness
ASR Silicone Straight Coupling Hose:
25mm - Rm25.00
32mm - Rm25.00
35mm - Rm25.00
38mm - Rm25.00
45mm - Rm30.00
48mm - Rm30.00
51mm - Rm30.00
54mm - Rm35.00
57mm - Rm35.00
60mm - Rm35.00
63mm - Rm40.00
63mm - Rm60.00
65mm - Rm50.00
68mm - Rm50.00
70mm - Rm50.00
76mm - Rm50.00
76mm - Rm70.00
80mm - Rm50.00
83mm - Rm50.00
89mm - Rm55.00
96mm - Rm160.00
102mm - Rm60.00
102mm - Rm110.00
ASR Silicone Straight Pressure hose are manufactured from high grade silicon polymer, and reinforced with high strength polyester fabric. This gives a minimum/ maximum operating temperature range of -40ºC to +180ºC. For operating parameters outside of these limits please inquire.
Specifications:
- Flexible
- 3 Layer
- Wall thick 3.5mm
ASR Silicone Straight Pressure Hose:
6.5mm - Rm100.00/Meter
8.0mm - Rm100.00/Meter
9.5mm - Rm115.00/Meter
11mm - Rm130.00/Meter
13mm - Rm170.00/Meter
16mm - Rm190.00/Meter
19mm - Rm190.00/Meter
22mm - Rm230.00/Meter
25mm - Rm230.00/Meter
28mm - Rm250.00/Meter
30mm - Rm270.00/Meter
32mm - Rm270.00/Meter
35mm - Rm270.00/Meter
38mm - Rm300.00/Meter
41mm - Rm315.00/Meter
45mm - Rm340.00/Meter
48mm - Rm340.00/Meter
51mm - Rm270.00/Meter
54mm - Rm390.00/Meter
57mm - Rm425.00/Meter
60mm - Rm425.00/Meter
63mm - Rm335.00/Meter
63mm - Rm470.00/Meter
65mm - Rm480.00/Meter
68mm - Rm480.00/Meter
70mm - Rm480.00/Meter
76mm - Rm360.00/Meter
76mm - Rm500.00/Meter
80mm - Rm490.00/Meter
83mm - Rm500.00/Meter
89mm - Rm420.00/Meter
96mm - Rm1000.00/Meter
102mm - Rm460.00/Meter
102mm - Rm750.00/Meter
ASR Silicone Straight Hump hose are manufactured from high grade silicon polymer, and reinforced with high strength polyester fabric. This gives a minimum/ maximum operating temperature range of -40ºC to +180ºC. For operating parameters outside of these limits please inquire.
Specifications:
- 3 Layer
- Wall thick 3.5mm
ASR Silicone Straight Hump Hose:
50mm - Rm50.00
60mm - Rm55.00
63mm - Rm65.00
70mm - Rm90.00
76mm - Rm90.00
102mm - Rm110.00
ASR Silicone elbow 45' hose are manufactured from high grade silicon polymer, and reinforced with high strength polyester fabric. This gives a minimum/ maximum operating temperature range of -40ºC to +180ºC. For operating parameters outside of these limits please inquire.
Specifications:
- 3 Layer
- Wall thick 3.5mm
ASR Silicone Elbow 45' Hose special for L2/L5 Intercooler:
Elbow 45' Reducer 44mm > 40mm - Rm110
Specifications:
- 3 Layer
- Wall thick 3.5mm
ASR Silicone Elbow 45' Hose:
Elbow 45' 51mm - Rm70.00
Elbow 45' 54mm - Rm75.00
Elbow 45' 57mm - Rm75.00
Elbow 45' 60mm - Rm75.00
Elbow 45' 63mm - Rm85.00
Elbow 45' 76mm - Rm100.00
ASR Silicone elbow 90' hose are manufactured from high grade silicon polymer, and reinforced with high strength polyester fabric. This gives a minimum/ maximum operating temperature range of -40ºC to +180ºC. For operating parameters outside of these limits please inquire.
Specifications:
- 3 Layer
- Wall thick 3.5mm
ASR Silicone Elbow 90' Hose:
Elbow 90' 8.0mm - Rm20.00
Elbow 90' 9.5mm - Rm20.00
Elbow 90' 11mm - Rm25.00
Elbow 90' 13mm - Rm25.00
Elbow 90' 16mm - Rm25.00
Elbow 90' 19mm - Rm35.00
Elbow 90' 22mm - Rm60.00
Elbow 90' 25mm - Rm60.00
Elbow 90' 28mm - Rm60.00
Elbow 90' 30mm - Rm70.00
Elbow 90' 32mm - Rm70.00
Elbow 90' 35mm - Rm85.00
Elbow 90' 38mm - Rm85.00
Elbow 90' 41mm - Rm85.00
Elbow 90' 45mm - Rm85.00
Elbow 90' 48mm - Rm85.00
Elbow 90' 51mm - Rm85.00
Elbow 90' 54mm - Rm90.00
Elbow 90' 57mm - Rm110.00
Elbow 90' 60mm - Rm110.00
Elbow 90' 63mm - Rm110.00
Elbow 90' 65mm - Rm125.00
Elbow 90' 68mm - Rm125.00
Elbow 90' 70mm - Rm125.00
Elbow 90' 76mm - Rm130.00
Elbow 90' 80mm - Rm170.00
Elbow 90' 83mm - Rm180.00
Elbow 90' 89mm - Rm220.00
Elbow 90'102mm - Rm240.00
ASR Silicone elbow 135' hose are manufactured from high grade silicon polymer, and reinforced with high strength polyester fabric. This gives a minimum/ maximum operating temperature range of -40ºC to +180ºC. For operating parameters outside of these limits please inquire.
Specifications:
- 3 Layer
- Wall thick 3.5mm
ASR Silicone Elbow 135' Hose:
Elbow 135' 51mm - Rm120.00
Elbow 135' 54mm - Rm150.00
Elbow 135' 63mm - Rm170.00
Elbow 135' 76mm - Rm250.00
ASR T-Bolt Stainless Steel Hose Clamp, extreme tight.
Specifications:
- Stainless Steel
- Non Rusty
- High Quality
ASR T-Bolt Stainless Steel Hose Clamp available size and Pricing:
T-Bolt Hose Clamp 35mm - 50mm - Rm12.00
T-Bolt Hose Clamp 41mm - 46mm - Rm12.00
T-Bolt Hose Clamp 45mm - 49mm - Rm12.00
T-Bolt Hose Clamp 46mm - 52mm - Rm13.00
T-Bolt Hose Clamp 50mm - 58mm - Rm13.00
T-Bolt Hose Clamp 54mm - 61mm - Rm13.00
T-Bolt Hose Clamp 60mm - 68mm - Rm15.00
T-Bolt Hose Clamp 63mm - 71mm - Rm15.00
T-Bolt Hose Clamp 66mm - 74mm - Rm15.00
T-Bolt Hose Clamp 69mm - 77mm - Rm15.00
T-Bolt Hose Clamp 73mm - 81mm - Rm15.00
T-Bolt Hose Clamp 82mm - 90mm - Rm17.00
T-Bolt Hose Clamp 85mm - 93mm - Rm17.00
T-Bolt Hose Clamp 88mm - 96mm - Rm18.00
T-Bolt Hose Clamp 95mm - 103mm - Rm18.00
T-Bolt Hose Clamp 101mm - 109mm - Rm20.00
T-Bolt Hose Clamp 108mm - 115mm - Rm20.00
*Price might change without notification, kindly contact me to confirm the price. TQ
*Please Inquiry / Order by E-mail
Website:
www.xd-auto.com
Contact No.: KentGoh - Digi 6 - 337 3368
E-Mail: [email protected]
Shop Location: Kepong Jaya Jusco
Installation & Tuning: Kepong Jaya Jusco
Business Hour: 10.00am - 7.00pm (Monday - Saturday)
Lunch Time: 1.00pm - 2.00pm
Delivery Service: 11.00am - 6.00pm (Monday - Saturday)
Our shop:
Win Hong Auto Trading Sdn Bhd
No.153, Jalan Besar Kepong, 52100 K.L
Maps: Wikimapia - Let's describe the whole world!
Dear All Members and Forumers,
I would appreciate if you guys kindly DO NOT PM/Call to me especially on XD-Autoparts related Products, Quotation, Technical Issues and etc.
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi 6 - 337 3368. This is to ensure better tracking and a more efficient follow up.
Thank you for understanding, cheers.
Regards,
KentGoh
Engine Performance & Compartment
ASR Silicone Hose - http://www.zerotohundred.com/newfor...s-asr-silicone-hose-products.html#post4121197
Auto Service & Replacement Parts - http://www.zerotohundred.com/newfor...cement-and-performance-parts.html#post3858120
Bardahl Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341331-wts-bardahl-fully-5w30-and-5w40-rm85.html
Bosch Fusion Spark Plugs - http://www.zerotohundred.com/newfor...ance/237425-wts-bosch-fusion-spark-plugs.html
Bosch Type-R Oil Filter - http://www.zerotohundred.com/newfor...mance/244853-wts-bosch-type-r-oil-filter.html
Chemlube Lubricants - http://www.zerotohundred.com/newfor...chemlube-100-syncthetic-with-ester-based.html
Cold Air Intake Hose - http://www.zerotohundred.com/newforums/engine-and-performance/234747-wts-cold-air-intake-hose.html
Exedy Clutch - http://www.zerotohundred.com/newfor...ce/341326-wts-exedy-clutch-and-fly-wheel.html
Forged Racing Radiator - http://www.zerotohundred.com/newforums/engine-and-performance/362689-wts-forged-racing-radiator.html
Pivot Products - http://www.zerotohundred.com/newfor...223310-wts-genuine-pivot-raizin-products.html
Haydens ATF Cooler - http://www.zerotohundred.com/newfor...-hayden-transaver-all-weather-protection.html
Denso Iridium Spark Plugs - http://www.zerotohundred.com/newfor...nce/303916-wts-denso-iridium-spark-plugs.html
K&N High Flow Filter - http://www.zerotohundred.com/newfor...-n-high-flow-drop-in-and-open-pod-filter.html
Motul Lubricants - http://www.zerotohundred.com/newfor...ance/223342-wts-motul-lubricant-products.html
Pennzoil Lubricants - http://www.zerotohundred.com/newfor...ance/341332-wts-pennzoil-platinum-series.html
Q8 Lubricants - http://www.zerotohundred.com/newforums/engine-and-performance/341333-wts-q8-lubricants-products.html
Redline LCP - http://www.zerotohundred.com/newforums/engine-and-performance/322721-wts-redline-lightening-crank-pulley.html
Hot InaZma Products - http://www.zerotohundred.com/newfor...-products-hot-inazma-hot-earth-hg-pocket.html
Torco Lubricants - http://www.zerotohundred.com/newfor...41337-wts-torco-sr-1-and-sr-5-lubricants.html
Works Air Intake System - http://www.zerotohundred.com/newfor...-wts-works-engineering-air-intake-system.html
Works Cam & Crank Pulley - http://www.zerotohundred.com/newfor...s-works-engineering-cam-and-crank-pulley.html
Works Drop In Filter - http://www.zerotohundred.com/newfor...724-wts-works-engineering-drop-in-filter.html
Works Fuel System - http://www.zerotohundred.com/newfor...341343-wts-works-engineering-fuel-system.html
Works Magnetic Oil Sump Nut - http://www.zerotohundred.com/newfor...-works-engineering-magnetic-oil-sump-nut.html
Works Oil Cooler - http://www.zerotohundred.com/newfor...ering-oil-cooler-engine-and-transmission.html
Works Oil Filter Relocator - http://www.zerotohundred.com/newfor...s-works-engineering-oil-filter-relocator.html
Works Racing Power Steering Tank - http://www.zerotohundred.com/newforums/engine-and-performance/341350-wts-works-engineering-racing-power-steering-tank.html
Works Throttle Body - http://www.zerotohundred.com/newfor...rks-engineering-power-plus-throttle-body.html
Works Sensor Adapter - http://www.zerotohundred.com/newfor...-wts-works-engineering-sensor-attachment.html
Works Silicone Hose Kits - http://www.zerotohundred.com/newfor...wts-works-engineering-silicone-hose-kits.html
Works Thermal Wrap - http://www.zerotohundred.com/newfor...41355-wts-works-engineering-thermal-wrap.html
Chassis & Handling
APM Performax Suspension Products - http://www.zerotohundred.com/newfor...6-wts-apm-performax-products.html#post3053352
Bendix Metal King Brake Pads - http://www.zerotohundred.com/newfor...ts-bendix-metal-king-titanium-brake-pads.html
Brembo Standard Disc Rotor - http://www.zerotohundred.com/newforums/chassis-and-wheels/341309-wts-brembo-standard-disc-rotor.html
EBC Brake Pads - http://www.zerotohundred.com/newforums/chassis-and-wheels/362688-wts-ebc-brake-pads-made-in-uk.html
Eibach Pro-Kits Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/242432-wts-eibach-products.html
GAB Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/352610-wts-gab-suspension-products.html
Pro RS Steel Brake Hose - http://www.zerotohundred.com/newfor...42876-wts-prors-steel-braided-brake-hose.html
Tanabe Suspension - http://www.zerotohundred.com/newforums/chassis-and-wheels/359603-wts-tanabe-suspension-products.html
TEIN S-Tech Spring - http://www.zerotohundred.com/newforums/chassis-and-wheels/311108-wts-tein-s-tech-lowered-spring.html
TEIN Basic Damper - http://www.zerotohundred.com/newforums/chassis-and-wheels/289072-wts-tein-basic-damper-offer.html
TEIN Super Street - http://www.zerotohundred.com/newforums/chassis-and-wheels/289071-wts-tein-super-street-offer.html
Ultra Racing Bars - http://www.zerotohundred.com/newfor...-wts-genuine-ultra-racing-stabilizer-bar.html
Exterior & Body
Bosch Aerotwin Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/228047-wts-bosch-aero-twin-wiperblades.html
Dyno Silicone Wiperblades - http://www.zerotohundred.com/newforums/exterior-and-body/303917-wts-dyno-silicone-wiperblades.html
Goodyears Graphite Wiperblades - http://www.zerotohundred.com/newfor...ts-goodyears-silentarmor-graphite-wipers.html
Philips Light Bulb - http://www.zerotohundred.com/newforums/exterior-and-body/229529-wts-philips-lighting-products.html
Tanabe Number Plate Holder - http://www.zerotohundred.com/newforums/exterior-and-body/238776-wts-tanabe-number-plate-holder.html
Interior & Cockpit
Works Gear Knob - http://www.zerotohundred.com/newfor...6-wts-works-engineering-teflon-gear-knob.html
I'm more than glad to answer you guys if you guys inquiry by E-mail to [email protected] or SMS to Digi - 337 3368 / Celcom - 266 8138 . This is to ensure better tracking and a more efficient follow up.
Regards,
KentGoh
