[WTS] APEXi I-Moni
[WTS] APEXi I-Moni
ftzone
full throttle zone
Brand New !
Price : *RM5xx
please message or call 016.4539687 for best price.
Actual Product
http://i22.photobucket.com/albums/b309/wiragsr/P4120168.jpg
Product Description:
A'pexi is proud to introduce the new "i" series of electronics. The "i" series allows the user to access and monitor critical data directly from the car's ECU by connecting to an ISO 14230 diagnostic port on OBD 2 (Onboard Diagnostic) vehicles 1996 and up. Installation is as simple as plugging the i-moni directly into the factory diagnostic port. The "i" series of electronics are compatible with almost any car using an ISO 14230 diagnostic port making it usable on a large number of OBD 2 vehicles.
- Segment LCD Display for enhanced daylight visibility.
- Display Parameters*: Engine RPM, Vehicle Speed, Battery Voltage, Intake Air Temp, Water Temp.
- Unit displays in both km/h and MPH for the vehicle speed, as well as Celsius and Fahrenheit for all temp readings.
- Unit also has a peak hold function.
Note: *Some vehicles may not display all parameters listed above. Parameters vary according to vehicle model.
Vehicle Tested:
Toyota VIOS / ALTIS - RPM, Water Temp & Speed
Honda CRV i-vtec
Honda City / Accord / Civic (year 2005 and above) confirmed.
Vehicles Supported as per manual:
Honda S2000, Integra DC5, New Accord, City 2005, Civic 2005
Most new Toyota vehicles. i.e Altezza/Caldina/Vios/Altis etc.
Mitsubishi EVO VII, VIII, IX
Subaru Impreza GC8 (1996 onwards) and version 8/9
Direct link : http://www.apexi-usa.com/product_electronics_detail.asp?id=250&pageNum=1
http://www.apexi-usa.com/graphics/products/2503.jpg
Vehicles NOT Supported even if you have the OBD2 socket. ISO different.
Perodua Kenari / Kelisa / MYVi
Hyundai ATOS
most vehicles manufactured after 1996 have ISO 14230 diagnostic port on OBD 2.
if you go and look under your dashboard, usually under the steering column, you should be able to see a female socket... thats the socket you'll use with the i-moni device. Also, workshops uses this port for diagnostic.
the location of the socket is as per attached in the attached thumbnail.
Here is a list so far I know the I-Moni support:
Honda CRV K20A manufactured after 2001 is supported.
Honda DC5 / EP3 Type-R K20A
Honda Accord CL1, CL3, CF3, CF4 & CF5 - H22A/F20B Manufactured after 1999
Honda S2000
Subaru GC8 EJ20 after 1999
Mitsubishi EVO VII, VIII - CT9A both AT/MT Transmission supported.
Daihatsu L9xx Manufactured after year 2000.
Toyota Altezza GXE10, SXE10
xcheong, how are u? :)
I have no idea 4G13P with siemens ECU is equipped with OBD2 ISO14230 port. You may need to ask your local proton dealer.
This i-moni only supports ISO14230 otherwise it will not work.
the answers will be the same. whatever vehicle fitted with OBD2 ISO14320 port will be able to use the "i-moni" Usually vehicles manufactured after 1996. I suppose JAZZ GD1 is supported.
It is your responsiblity to check and ensure that your vehicle is the ISO14320 standard. Failure to do so, a restocking fee of RM50 is chargeable if you decide to return the unit.
eheh yeah, good statement.
btw, ftzone, i'm fine.
sorry for the MIA.
got a few stuff wanna get from u. but have to wait till end of the month. car got too many problem already. all fix no mod. ;(
-update-
The i-moni works perfectly on Toyota Vios 1.5 & Toyota Altis
Will display the following:
RPM
SPEED
WATER TEMPERATURE
Installation is a breezeeeeee... no messy wirings
as long as you have OBD2 Port and ISO14230 Standard you will be able to use it.
